WIW 340 exhaust heat riser kit
6T4polara
michigan
NOS kit not in original wrapper but all the parts.
What does the valve measure across in diameter?
The early 340 manifold kit is different than the later kit.
BIG price difference
This is an over $150 kit. Lot more, if 340. I bet some parts flippers are already PM’ing him
The repro is $150
Here’s the repro for $145
Heat Riser Kit 1968-70 340, Exhaust Manifolds/Components, 199-DR085 Reproduction, NOS and Used Mopar Muscle Car Parts
It does not have stamping on the round weight like originals.
I think even most (all?) NOS is actually different than OE. Originals factory ones have a thin round weight.
Read here: Anyone know if there are 340 heat riser kits available?
I saw one 68-70 NOS from Brads NOS for $389. Says out of stock
He’s always high and gets full retail for his parts. And will sit on them to get it.
I’m thinking true sale for a 68-70 no package ALL parts is $200-250 Like here from 2017 eBay listing:
Do you have EVERY PART shown in the ad in you no-box kit?
A later 318/360 on sold here for $83:
[FOR SALE] - NOS Mopar heat riser kit 72 - 73 340 360 part number 3683947
So you better find out which on you have.
I think that may be for a big block. The 340 kit should not have that extra (black) bracket/weight. The thin weight was used on early 340's.
The 340 T/A repos on ebay lack any heat riser. Did T/A casting have a riser?
Not sure if the original TA 340 had a heat riser but I think they did. They were left off the repro basically for cost plus the fact that most people remove them anyways.
2 1/4" butterfly. That should make it for a 340 or 360 unless it fits a big block. I'm not up on my counterweights but it looks like it could be from a big wedge.
It is 2 1/4” to give sufficient clearance..
Just measured mine in garage
Here’s the 68-69 repro kit:
