Would a 360 be a good engine for a first time driver?
A 360 will be a good engine for your Sport. Find out more about it and don't be afraid to come back here and ask questions. Find out what year engine it is, because it could possibly be a 5.9 Magnum from a later truck or van. 5.9 Magnums are 360 cubic inches also, but are balanced differently, even though both are externally balanced engines. Nothing wrong with that at all, just knowing info like that will help us help you.
:thumbsup:
The 5.9 Magnum motors will give you the most bang for your buck, the only problem I've run into is the heads cracking between the valve seats. Even then, if the heads are not leaking, drive it like you stole it.
My first car was a 70 Dart Swinger /6 at 17 years old. After getting sandwiched on a rainy Monday. My next car was a 70 Roadrunner with a 383 and was known as the fastest car in town. It was the next owner of the Roadrunner that wrecked it. Drive like you want to keep it.
My 1st ride Is a Dodge dart sport with a slant 6 transplant (out of my dad's wrecked dart sport). I was never thrilled by its output but it got me from point a to point b reliably. Then years later an uncle decided to sell his 1975 chrysler Cordoba 360. I bought it and removed running gear for my dart. Rebuilt the 360 with KB107 pistons and slid a 280 mopar cam. Windage tray ld4b intake thermoquad and beefed up the 727 also Rebuilt. Car ran much nicer. Only major drawback were the pathetic 2.45 gears in the 8.25!!
Most V6 now days have more power than a stock 360, of course a 360 can become powerful with mods, like many have said any engine can kill ya.
a free 360 is a great motor. lots of affordable and available parts, reliable and respond well to upgrades.
Agreed!! FREE is a key word and the engine is a solid platform to build on :thumbsup:
To tack onto @Scody21's post:
You will drive modern cars. Modern cars are different. At this point, they are all computerized, and they all have some sort of traction control, or at least ABS.
Older cars are not like this. They do not think for themselves. They follow the laws of physics, and do what you tell them to, so long as it doesn't conflict with the former.
You need to gain an understanding of traction, and how it changes with conditions, such as water, snow, ice, different surface types (asphalt, concrete, etc), and so on.
You need to understand the basic concepts of understeer and oversteer. An older American car will understeer badly, and, depending on conditions (such as wet roads), may suddenly convert to oversteer. You need to know what these are, and have the physics they describe operating in your brain as you drive, because the car does not have a computer that is doing that for you.
You need to understand what is "just enough" and what is "too much" for your particular car in its current state, and avoid doing things that bring out the latter.
You need to understand that an older American car will be light in the rear, and will be easy to provoke to "step out" (have the rear go sideways) with the application of too much power. This is the main place where the safety difference between a Slant-Six and a 360 will come in.
Ultimately, you need to understand and follow famous racer Stirling Moss's quote,
"It is better to go into a turn slow, and come out fast, than to go into a turn fast, and come out dead."
A whole lot of kids used to die behind the wheel when we were all younger, It happens less now, and a lot of that is because cars are safer. You need to be aware that you can't screw around like you can in a modern car.
Good luck and enjoy it!
- Eric
I am wondering if it would be good for a first time driver like myself.
Absolutely yes.
1) You don't have to push it as hard as you would 318, for the same performance, and
2) it has the potential to get at least the same to better fuel-economy, and
3) it will have better passing power and
4) that's just as a 2bbl.
IMO,
1) a 318 gets you into trouble, while a 360 gets you out.
2) Make sure your car has good brakes and a good working Sure-Grip.
Absolutely yes.
IMO,
Nice Segue :)
Absolutely yes.
IMO,
everything here is some kind of sideways reasoning that's thinly veiled 318 hate.
true you won't have to push it as much for the same performance, but if that goal is low it's totally a moot point. if the goal is 300hp i don't see it as even entering the realm of considerations.
your opinion on making sure that the car has good brakes is well founded, and i agree with that fully.
everything else gets a hard eye roll.
You’d have to ask him what “pushing it” means. It’s obtuse for a reason.
