cannucky
The Guy With No Birthday
subscribed
can i ask what so special about the x block and what year did they come in or is this a aftermarket block, and I'm cures about what kind of heads you plan on using only reason, I'm asking is next year I'm putting a 70 challenger together 4 speed car i have a 6 pack set up for it already and i think a stroker 440 small block would be a great set up i like, what yours is looking like sorry to pry. I'm looking to spend 9to 12 grand on the engine . will be the budget.
Somewhere along the way some of you guys got the impression that DJV is building his engine with a 4.250" stroke. He is using one of my 4.125" stroke cranks. Just wanted to clear up any confusion.
Rod
you are right - i caused alot of confusion here - let em see if I can fix it and make 2 threads.
have you decided what cam you are going to run hydraulics or solid roller to make those numbers you going run in the 600 lift area i did a 426 stroker, and ran into some weird issues like, the front harmonic balancer hit the timing cover right were the timing marks were . but this was on a magnum engine are you going to run the oil line in the top of the block or are you going to drill out your lifter galleries and give your cam bearings a smaller hole to keep the oil down below are you going to run a girdle, are you going to run dry sump or a regular oil pump system ow and don't forget to make room for you dipstick i screwed up on that one what rocker are you going to run? 1.6 or 1.7 , ow and don't for get the little oil plug in the block you said it got rot to blasted a lot of people don't know about that plug and cost them a engine . aw man i cant wait to hear this thing run .
