SRT_DSTRHOLC
So the oil pressure issues I was questioning were true...Took the motor apart to check them and I found little pieces of metal in the pan. I also have a piece of metal I found. The main bearings are not as bad as the rod, but there are some none shiny parts which I dont know if its bad? I believe this happened when I got antifreeze into the oil. check the pics
