duster731
young gun
I've asked this before but I feel a bigger cam would be better.......
What I have going in is the comp xe268.
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=627&sb=2
What I'm thinking about is a Herbert cam
http://www.dougherbert.com/sb-chrysler-hydraulic-flat-tappet-cam-lifters-9671.html
RPM Range: 2500-6600 Advertised Duration: 285/295 Duration @ .050: 230/235 Lift: .480/.495 Lobe Center: 106c Chrysler V8 64-91 273-340-360(5.9L) & 67-91 318 SB Chrysler Hydraulic Flat Tappet Cam & Lifters-Hot street/strip dual purpose cam. Strong mid-range to top-end.
The set up will be...
302 heads 188-160 ported to flow about 220cfm and maybe milled to raise cr
Stock bottom end 40 over I think 8.1 compression
Edel air gap
650 dp
Hooker headers
Manual v.b 904 lower first gear 2800 stall
3.91 s.g
Stock ignition
And still debating on a 125-150 shot of juice
So what do you think I'm debating on selling the comp cam I have sitting at home and getting the Herbert cam..... Thanks
Edel air gap
650 dp
Hooker headers
3.91 s.g
Stock ignition
