Details of the "build" are sketchy at best. What I have is a late model, roller cam 318 short block on the stand that I want to build for my '65 Valiant. The car will be a sort of combination cruiser/long hauler/pro touring-ish deal so drag racer style performance is not a priority. That being said I still want enough oats to spank the backwards baseball cap, green haired, multi-pierced punk next to me in the 'stang......sort of a "up yours, sonny, you just had your *** waxed by an old fart" deal. I have been thinking, if the block will take a 40-thou over-bore, of dropping in a 4" cast stroker crank for a small bllock 392. That number has some chops in my mind, 390 (Ford and IH number) does not. Keep it pump gas friendly with good heads, flat top pistons, Performer RPM-ish intake, maybe a self learning injection set-up, TTI Headers to my existing 2 1/2" dual Exhaust system, stoutly built low gear set 904/999, with a 2.94 geared 8 3/4 suregrip out back. Option B transmission would be a 5-speed manual, 5 TH gear overdrive, and a 3.23 out back. Commments and/or suggestions welcome here.
The EQ heads will flow right at 250 out of the box and closer to 260 with 2.02 intake valves for just under $1,100.00. Dollar for dollar I would have at least that much in a set of ported 308 heads built along the same order as the EQ's. I'm not saying that the 308 are not a good value providing you are handy with a die grinder....I'm not.
Bob
