Post your wheel and tire combos.
Ford Mustang 17 x 8 - 5.72 B.S.
Nitto NT450
225/50-17 front
275/50-17 rear
Still in the build stage, but they fit nice. I machines them to the specs in my build thread, and there are no issues.
'80s 7J Dodge wheels with 215/60 Goodyears on the front and 225/60/15 Bridgestone's on the rear.
I dig those wheels .. what do you mean "80's 7J Dodge Wheels" ? What is a 7J?
Here is my 70 Dart. The rear is narrowed to 56 1/2" from WMS to WMS. The rear is moved back 1.25". The wheels are Ridler 695's
18x8" in the rear with 4.5" BS
255/45/18 (27" tall)
17x7" in the front with 4" BS
25.6" tall tire in the front (plan on going with a shorter tire)
Front
BF Goodrich T/As 205 60 15
classic industries steel 15x7 wheels
4" back space
stock suspension
back
BF Goodrich T/As 245 60 15
classic industries steel 15x8 wheels
4" back space
stock suspension - rolled quarter lips
You say rolled quarter lips...does that mean they're just slightly too wide? I ask because I just bought the EXACT same wheel combo from Classic Industries and now looking for tires.
nice Dart BTW:thumrigh:
For a blue Dart, that looks damn good!
Thanks, so far I got a lot of inspiration for it from your car. Your car is what keeps me thinking to keep it blue instead of HOK Tangelo Orange, when I paint it.
Whats your fender tag say for paint? Im guessing B7? I painted mine back to its original B5 because
1. I like it
2. I couldnt afford a color change at the time
3. The under side of the trunk etc. were still in great shape and original.
attachment.php
73 Custom with BBP 7¼ rear, BBP disk brakes.
Magnum 500s 15 x 7, 4¼ BS.
Tires are Riken 205/60-15. No tricks to body, tires don't rub.
attachment.php
attachment.php
72 Demon. 7¼ w/ bbp, front end is BBP conversion.
Wheels are Mopar 15 x 7 with 4¼ back space.
Tires are 235/60-15 radial T/A. Fender wheel openings massaged mildly. Fenders mounted slightly wide. Rub during extreme movement only
Rear tire rubs in wheel well under extreme jounce situations
Car year and model - 1968 Aussie valiant sedan
Front Wheel
Brand- convo pro
Size - 15x4
Backspacing - 2" I think
tire size - 28x4.5 MT
Suspension mods - stock
Rear Wheel
Brand - convo pro
Size - 15x12
Backspacing - 3 3/8"
tire size - 28x11.5 ET Drag
Suspension mod - chassis connectors, relocated springs, mini tubs
1973 Dart Sport
Front:
Cragar S/S
15"x7"
Backspacing (not sure)
Cooper Cobra Radial G/T 235/70/15
Had to work the fender a little bit so they would clear, also lengthened the fender brace.
Rear:
Cragar S/S
15"x10"
Backspacing 4'
Cooper Cobra Radial G/T 295/50/15
Stock springs with adjustable shackles and air shocks
How about some big and skinnies. Picked these up used last week. Rears are 15x12 ansen sprints with 17.5x32 M/T DOT cheater slicks and fronts are 15x3.5 fentons with V dub tires. The rears look huge next to my Dart with SS'd wheel openings. I have another chassis I am building to use these on.
1974 Dart Swinger
Front
Wheel Brand: American Racing Outlaw 2
Size: 15 x 7
Backspacing: Don't know - but 0 offset...
tire size: 205/60 R 15 BFG G-Grip
Suspension mods: none
Rear
Size: 15 x 7
Backspacing: 0 offset
Suspension mod: none
Ok, here we go
1974 Plymouth Duster
Front
Wheel brand: Enkei RPF1
Backspace: 6.4" backspace (35mm offset)
Suspension mods: Magnumforce tubular UCA's, Dr Diff 13" brake kit (adds 3/16" to track width), rim center hub bore opened up to clear front hubs
Rear
Wheel Brand: Enkei RPF1
Backspacing: 7" (38mm offset)
Tire size: 295/35/18
Suspension mods: 68-70 B body rear (54 15/16" flange to flange), 1/2 spring offset, 1/4" quarter lip trim
Nice Duster. Those wheels really take the Happy Gilmore look away from it. : )
Those wheels are awesome
Fronts are BBP 15x8" Cop wheels with 235/60R15 BFG's. Rears are custom SBP 15x8 with 5" back spacing and 255/60R15 BFG's. The front's fit perfectly with no rubbing at all. The rears are the biggest tires I could fit without any interference. It's tight, but it works.
