heres my list
1969 barracuda hood fits 1973 up dart, and vise versa. there was no chrome insert version for 1969. a 69 only flat hood with raised center hump, or the same hood with 2 tacked on forward facing scoops 'Cuda editions had this.
67 up A , B, C body. The outer door handles will fit off dodge pickup or ram van up to and including 1993, you may have to use your original linkage behind your original door handle button. the housings and button are the same tho.
dodge pickup for 1981 to 1993, and dodge daytona from 1988 to 1991 use the same front fender amber parking light lenses as A body and B body cars from 72up. only difference is the trim edge is painted black instead of silver.
the rear (red) parking lamps from a plymouth horizon/dodge omni from 1978 to i think 1989 fit A and B body cars from 72 up.
not sure but i believe the front door window regulators from a 4 door A body will fit a 2 door.
A body door hinges. chrysler only made 1 upper, and 1 lower. not LH and RH. if the drivers door lower hinge is slopped out on your 2 door, get one off the passenger side front door of a 4 door. shorter door less weight, plus passenger side less use as well. just flip it over, and it works.
(not sure but i think the lower hinges for A body and B body are the same. if so the ones for a ram pickup up to 1993 (old style cab) will work, i believe an additional hole needs to be drilled to use on A and B body cars.
power steering feel a bit floaty and over assisted ?? get a PS pump pressure regulator valve off a slant six saginaw pump. this is on the high pressure side of the pump where the hose fitting attaches. unscrew the big nut on the back of the pump. the regulator is right there. this drops pump output pressure on a V8 pump from 1,200 PSI to about 850 PSI. enough pressure to park one handed, plus lower pressure for better road feel similar to a manual box car.
79 cordoba 11.75 " disc brakes, and 2.75" piston calipers on A body spindles. direct bolt in, dont forget to get the caliper mouints , and mount bolts. the bolts are longer than A body ones. dont forget a larger bore cordoba master cylinder.
apparantly M body V8 radiators bolt directly into at least 67 to 69 A bodies with no mods. holes in the rad supports line right up. these came in cars with 318s and 360s
stock magnum V8/V6 starters fit pre magnum V8s and slant sixes. its a compact hi po starter for boneyard prices.
matt
