Bakerlite
- Joined
- Nov 12, 2007
- Messages
- 6,431
- Reaction score
- 3,311
This is a new out of the box manifold. In fact the only other one of these I have seen prior to this one was about 7 years ago and it had the exact same problem. The casting and bolt hole angles for the manifold bolts are at an incorrect angle and because most of these come from the same factory and the same casting molds then I've got a feeling that this is a common problem with this brand. This could lead to poor clamping and leaks.
I think people should think twice before buying one of these. If you already have one then I would be checking it.
