stroked340
Im sure you wil stick with your stock replacement heads. But you are obviously not intrested in 700+hp either.
Stock replacement far from it..get a clue
Edelbrock heads (Not the Victor) are considered stock replacement heads, no matter what work was done to them by the end user or his porter.
Stock replacement heads are defined by but not limited to;
Using stock bolt patterns on exhaust and intakes. Valve gear/rockers. Valve covers.
Hummm, good question. One of the parameters to making that power would be head flow, it's abilty. On paper, the RPM should be able to so long as it is coupled with the right stuff.So I need the Victors to make 700 h.p. huh..all depends on who's building your motor..
very logical and very well saidGood parts are not cheap, I have right at $1000 in my Hedman headers including coating and my T&D rockers were almost $1100, push rods, almost $400. Quality parts that make or can withstand a bunch of power are not cheap. No matter what brand is on the hood.
Indy stuff can make excellent power when in the right hands and the correct parts to compliment them. I bought mine used un ported and called Indy just to pick their brains a little. I was on the phone with them for about 15 minutes and never felt like I was being put down or hurried to get off the phone. Having said that I have read the horror stories too so there is some issue there. I've read of many people having issues with Dave Hughes too, but I've had many conversations and never had an issue.
With small blocks getting bigger all the time we need heads that will support them. If you're running a stock stroke 340 with a purple shaft cam the new Edelbrock Victors or Indy heads are not for you.
I have a very good set of Edelbrocks that were on my 408 but when I built the 434 I knew they would be a restriction. I have no regrets using Indy heads on it.
Your mileage may vary.
Is someone really making 700HP with the stock replacement style Edelbrock heads?
How much HP from SBM ProComps? Well... 670HP!
This is pretty damn close and with a bit more CR and cam perhaps depending on the heads etc....I would say its possible.
I think it possible but only in true race trim. Something you would never drive the street in. Gasoline Fuel NOT available at the pump.
(Or is it????) At 720 hp per cube...
It would be a 2hp/cube build for a 360.
1.76 hp/cube on a 408.
1.65 hp/cube for a 434 stroker.
Getting easier......
A 360 making;
1.50 per cube, it is 540hp,
1.65 per cube it is 594 hp.
1.76 per cube it is 633 hp.
. 720hp (a 434)
- 633hp (a 360)
= 87hp. That's a lot of hp and stress at this level.
I have heard and love that sound, just can't afford to make that kind of sound! and a stick shift car to boot.Cudafever, I don't know nothin on getting these things to spin 10K, or anything else, but I do know that if a need, needs to be filled, if there's a will, there's a way.
Rumble I really don't think he is trying to start a pissing match. And i'm not either but i kinda have to agree with him.
Here is my mind set.
Can a 340/360 head be ported to make 270 cfm? YES i have done it. but not before i found water and broke into the roof on one of the spring pads.
I bought a set of rhs head and had IMM put 2.02 in it and maching spring for my cam. Had to flow test them heads before i installed them
they flowed 274 cfm at the lift i have for my cam.
They were way quieter and stable flow. at that same cfm.
Them rhs head got my 3860 pound car in the high 11s at 4400 feet. Not a chance in hell them 360 head i ported would have come even close to that kind of number, even thow they basically flowed the same cfm.
not even if i put a bigger cam in it.
This is what i think he is trying to say.................
