TomMoparMan
I'm curious numbers cause the higher the hp the easier it is to get those numbers by optimizing the electric side of the build. 18 hp gain from stock motor is not likely to happen unless their was a fowled or faulty plug which he stated is not the case.
Yes it is higher, just not as high as I was hoping for. Plug change went from 846 hp to 864 hp
