NO disrespect intended ;^)Ok Kemosabi..........Play through.
Not at all .1-3 of snow for the morning rush I was told.... just sayin....
Does the coolant smell like gas?
lol1-3 of snow for the morning rush I was told.... just sayin....
Little coolant in overflow.. about a inch low in radiator..have to fix the starting problem now..won't crank and no spark when jumping relay.. always something!!More importantly where was the coolant level in the recovery bottle this morning before trying to start it. Or in the Rad if you checked.
Going to chk that soon...don't know why the key isn't cranking tho??I would check battery cables, to starter and to block.
One cause of starter run on is low voltage, fusing contacts in starter.
Just did a thermostat in a chevy,overflow bubbled for a long time.
no spark, is key in run position while jumping relay?won't crank and no spark when jumping
Yes key in run .. going to chk all the ignition components I guessno spark, is key in run position while jumping relay?
I push started a old 63 econoline by rolling down a hill and only realized the key was not in run till I got to the bottom.
Going to r&r some parts ..need a mini starter anyway when I do headers..can get some parts for like nothing..so I'm doing relay ,ECU, and balister.will keep what I don't need in trunk for spare.and replace battery terminal and starter wire..and all other wires I see little suspect.. hopefully I will get it along the way.. weird issue s ..damn thing making me twitchyYes key in run .. going to chk all the ignition components I guess
No battery is still good.. checked again to make sure..didn't load test it bit has good -v-I hate this crap. It when ever the sit as long as yours has... this be the problem with them.
I have a dumb question! Did you leave the key in the on position to drain the battery down some?
(Sorry, just grasping here.)
Jump out the starter itself?
Freakin a bit chilly today with the wind!
What are you meaning with fusable link..I chk the few in line fuses I saw..but am I'm missing something obvious??Ummm, kind of under the weather here so, the brain has a fit in it, would the fusable link have a play in this?
I'm going to chk ignition switch..now that I'm noticing. When I usually turn the key I would see the volt guage move and it's not.. going to pull and chk everythingAnd quite difficult to diagnose over the internet.
Sorry new to the forum thought I could get more options and options if I put on different thread with title being different..is that not right to do ..if so please let me know not trying to be an ***And a new thread to complicate matters even more.
Not cranking over but will with relay but now no spark
I appreciate the help I know!!?And quite difficult to diagnose over the internet.
Hence my thought on the fusable link...I'm going to chk ignition switch..now that I'm noticing. When I usually turn the key I would see the volt guage move and it's not.. going to pull and chk everything
