purplehazenils
-----The rebuild:-----
So I rebuilt my Thermoquad a while back, the main well O-rings/X-rings were bad but I bought a whole kit to to change out other gaskets etc while I was at it.
I did the rebuild to about 85%, I didnt disassemble absolutely everything but I changed the main gaskets, rings, accelerator pump and some other stuff. I also did the adjustments to spec, it wasnt that far off to begin with.
----- The problem: -----
I cant remember if it was a problem from the start or if it happened a few days after use ... Anyway, the car runs and drives fine but you have to prime the engine/carburetor before you start it each time. Sometimes it will start without priming but if it dies when you put it in gear you have to prime it to get it going again.
I noticed that the two nozzles in the primaries which squirt fuel when you pump the carb dont squirt fuel anymore so I assume this is the problem. But what should I be looking for when I disassemble again? A somehow jammed accelerator pump?
