ok back to reality
are these bolts in shear or tension or both
If you used grade 8's wher a grade 5 was specked and used the factory torque you would not hurt anything, but you would not have as much clamp
lucky tolerance are large
on the motor mount torque is not as important as locknut or locktight
We moved the bolt thread over to the bolt thread post. Sorry.
