famous bob
mopar misfit
Geez...640$
I’d return it. I’ve had not much luck with MSD. And it’s only good for starting-3000
Rpm. So that’s a 50/50 or so success rate according to this post. Plus theyre screwy with the timing light.
You said you’re going efi soon, go buy megasquirt for the same price. Efi is a little tricky with it. You’d have to read up a lot. But...the megasquirt also allows full authority over ignition timing, independently from fuel control. Just add a coil for $60 and a Bosch ignition driver, $8.Lock out the distributor and you’re done. Tune ignition with your laptop on the fly.
In case u didn't notice, that's a fast 2.0 fuel inj. set up with that MSD stuff, everything is controlled on it by the F.I. too.
There seems to be a lot of people that want others to run what their running, and don't know squat about what their talking about .
3000 rpm , gimme a break !
I don't own a laptop , or want one , I can tune everything with my hand held too.
