Will Gant
Member
I recently had a shop press in new Moog UCA bushings (K408, non-offset) for my '69 Dart with front drums. Now that I have gone to put them in, both control arms don't fit in between the mounting ears. Did I buy the wrong bushings, or have the ears shifted with the old bushings? Could I bend the ears out with a hammer to get the new bushings to fit, or should I try getting the Moog offset bushings. I have attached a picture of the worse fitting arm, the other one goes into the bracket but doesn't line up well enough for both bolts to go through. Thanks in advance.
