ragtopfury
No worries. Hope it works out either way for you.
Can you buy a later one and swap the pulley to your style?
are you maybe prying it backwards?. Just trying to help.
What if you take it off and submerge it in your favorite lubricant/rust remover overnight?
Dion can you get it apart and replace the bearing? Or swap parts from another idler?
well that's it then.stuck between the two stops,
dayco, 89315
or so the interwebs tells me
same thing as the duralast 305315
I called the advanced auto and the autozone in hampstead, both of em claimed they could have it tomorrow
Maybe I should have you order one for me, I am coming up blank on the dayco number. I can find it on the web, but everything says "not available".
the way I went about it, I went to the dayco site
Dayco Catalog - Unites States & Canada
punched in the year make and model and the part number popped up
http://www.daycoproducts.com/part?oe_number=305315&part_number=89315
then there was a tab called (bottom right of the last page) "need this part?" [find stores]
I clicked on that and punched in "Manchester MD" (because I didn't pay attention and I got you confused with @ragtopfury , so the store in hampstead might not be as close as I thought)
so, once I popped in "Spokane WA" I got this
Where to Buy
since the advance auto store told me he could order it directly from the manufacturer, I would call them first
is this a dakota sport? i looked at advance and typed in sport w/318 and it came up as dayco 89434 or litens 910556a. none avail for p/u in store. had to order online. dayco over 100.00 w/o any discount and litens is 77.00 w/o any discount applied. i tried to have napa cross the 89315 and it would not cross. if you call dodge w/ vin they could give you mopar numberand also see if vintage parts had one or any other dealer in country has one. if not then google mopar number and see if any nos supplier has one.
