Have a lash adjustment question regarding Rhoads lifters when running them on a solid lifter cam. I spoke with Jack at Rhoads and they have a V-Max lifter that can be run on a solid lifter cam. So I ordered a set and they should be here next week.
He said lash adjustments are made using a feeler gauge much like you would with a regular solid lifter. With dry lifter (not pumped up and not having been soaked in oil beforehand) on heel of cam and feeler gauge in place between valve tip and rocker, carefully tighten lash to depress spring loaded plunger in lifter until it 'just' bottoms but does not lift valve off seat. Then tighten poly-lock and proceed to next lifter.
I am thinking that when setting lash, I should 'stack' tolerances. In other words...... Take the recommended hot lash for the solid lifter cam...... Add .002" for initial cold lash setting (iron heads and block)...... Then add the amount I want to use for delaying complete pump-up of the fast bleed down Rhoads lifter. He cautioned not to exceed 0.035" in all and the way I have it figured, I should 'just' be within that parameter...... 0.026" lash for intake and 0.028" for exhaust. Does that sound right to you guys?
Any assistance much appreciated,
Harry
Harry
