Stop in for a cup of coffee
They were great always had what you needed..
Yep, usually had some old timers that were working on cars longer than I was alive. Knew what I needed better than I did.
What's it for and what are you doing with it? Not what color is it and does it have leather seats? :BangHead:
Doesn't look up anything. Here's the original part, but hang on...Go to other shelf. This one from XYZ will work better because...:thumbsup:
And if you asked one too many questions they got grumpy and told you just use it and you can thank me next time you come in. LOL
Rockauto clearance, oil pan gasket, exhaust gasket and a couple wipers for the fargo,$30 to my door.
Cant get the wipers for that.
Gasket set is 18 my cost,wipers dont even come up in warehouse inventory. No way they are less than 10 apiece.
i started planting mine yesterday. Oh, those hops, the first sprouts are about 6 inches tall, i have two more spouts that are about 2 inches. but they came out sideways of the row from where they were planted. so I'm also gonna try to stake those up
No need for stakes. Just get strings up. Doesn't matter what direction they grow. when they are about a foot long put them on a string and they will go. Do 3 on the string and cut the rest off.
will do thanks! Probably just string them along some iron fence posts. Was looking on Ideas on line.
Yup, yur talkin bout my guys there.........Including myself, of course. I trained the younger ones......
So I'm going to try to hot wire the poly because I found that the fusible link is blown at the bulkhead connector and the wiring is a nightmare.
The car has points so someone refresh my memory on how to steal my own car lol
I need to get power to the distributor and then crank it at the selonid......
So they will grow sideways? easier harvesting than on a 50' ladder. LOL
Ask Chris. Not really. Just run a wire from the Batt plus to the coil plus side. Then use a screwdriver to jump the solenoid to turn over...
MAKE sure car is in park and brake set.....
this sounds familiar... So I will only tell you what I did that actually got mine to fire.
I ran a jumper from the 12v positive on battery to positive on coil @Mopar Tim 's suggestion, and then hooked a remote starter switch up on the suggestion of OMR, and now mine runs, and idles, somewhat while blowing smoke out the breathers.
12 volts to the positive side of the coil and jump the relay with a screwdriver.
