- Joined
- Jan 19, 2007
- Messages
- 64,400
- Reaction score
- 45,354
so it was supposed to be 82 and sunny today, its freaking pouring. Damn weather fuckers can't predict the weather any better than they can earthquakes
Yep, usually had some old timers that were working on cars longer than I was alive. Knew what I needed better than I did.They were great always had what you needed..
74? Dart Sport? IIRC
Nice here. Time to plant the garden.so it was supposed to be 82 and sunny today, its freaking pouring. Damn weather fuckers can't predict the weather any better than they can earthquakes
And if you asked one too many questions they got grumpy and told you just use it and you can thank me next time you come in. LOLYep, usually had some old timers that were working on cars longer than I was alive. Knew what I needed better than I did.
What's it for and what are you doing with it? Not what color is it and does it have leather seats?
Doesn't look up anything. Here's the original part, but hang on...Go to other shelf. This one from XYZ will work better because...![]()
i started planting mine yesterday. Oh, those hops, the first sprouts are about 6 inches tall, i have two more spouts that are about 2 inches. but they came out sideways of the row from where they were planted. so I'm also gonna try to stake those upNice here. Time to plant the garden.
So close! 73.. originally a 340 auto car.74? Dart Sport? IIRC
whats the plan?So close! 73.. originally a 340 auto car.
I remember when you bought that, good timesSo close! 73.. originally a 340 auto car.
giving it to mewhats the plan?
No need for stakes. Just get strings up. Doesn't matter what direction they grow. when they are about a foot long put them on a string and they will go. Do 3 on the string and cut the rest off.i started planting mine yesterday. Oh, those hops, the first sprouts are about 6 inches tall, i have two more spouts that are about 2 inches. but they came out sideways of the row from where they were planted. so I'm also gonna try to stake those up
will do thanks! Probably just string them along some iron fence posts. Was looking on Ideas on line.No need for stakes. Just get strings up. Doesn't matter what direction they grow. when they are about a foot long put them on a string and they will go. Do 3 on the string and cut the rest off.
Yup, yur talkin bout my guys there.........Including myself, of course. I trained the younger ones......Yep, usually had some old timers that were working on cars longer than I was alive. Knew what I needed better than I did.
I must have missed that post when I was backreadinggiving it to me
low and slow don't you knowWell, all caught up, Hows it hanging??
Squeezing one out?low and slow don't you know
So they will grow sideways? easier harvesting than on a 50' ladder. LOLNo need for stakes. Just get strings up. Doesn't matter what direction they grow. when they are about a foot long put them on a string and they will go. Do 3 on the string and cut the rest off.
Ask Chris. Not really. Just run a wire from the Batt plus to the coil plus side. Then use a screwdriver to jump the solenoid to turn over...So I'm going to try to hot wire the poly because I found that the fusible link is blown at the bulkhead connector and the wiring is a nightmare.
The car has points so someone refresh my memory on how to steal my own car lol
I need to get power to the distributor and then crank it at the selonid......
this sounds familiar... So I will only tell you what I did that actually got mine to fire.So I'm going to try to hot wire the poly because I found that the fusible link is blown at the bulkhead connector and the wiring is a nightmare.
yeah. dont ask chris on this one. Chris struggled for a long time on this one.Ask Chris. Not really. Just run a wire from the Batt plus to the coil plus side. Then use a screwdriver to jump the solenoid to turn over...
MAKE sure car is in park and brake set.....
12 volts to the positive side of the coil and jump the relay with a screwdriver.So I'm going to try to hot wire the poly because I found that the fusible link is blown at the bulkhead connector and the wiring is a nightmare.
