Dialing in a Carter AVS
I know you like short answers so;
on the forward half of the throttle valves,between the T-slots and the Idle ports, and about 1/3 of the way back towards the center point
BTW, if you put a 4-corner idle carb on a SBM, with a 223* or smaller cam, don't even bother trying to get the secondary idle circuits working. If you do, the primaries will likely be too far closed on the transfers, and you know what that leads to.
The long answer;
Well, I've been lambasted a few times for promoting the holes. But I've seen it done from the factory on all kinds of small equipment, especially outboard marine engines. I can almost guarantee you that nearly every piece of lawn and garden equipment, that you own, that has an idle position, has a butterfly with either a hole or a trimming.
And unless your 4bbl carb has a 4-corner idle system on it, the only correction for bypass air that I know of, is with either drilled holes, or PCV flow manipulation. I tried the PCV flow deal, but that didn't work out very well for me.
Since I wanted the bypass air to mix with the transfer discharge/idle discharge as quickly as possible, that's where I put my holes. Namely on the forward half of the throttle valves,between the slots and the ports, and about 1/3 of the way back towards the centerpoint. Mine was a Holley. The learning curve hit me hard. I kept drilling and tuning and drilling and tuning, and suddenly, the holes were too big; from 7/32 to 8/32 I found out, is a big change! Yeah I had to figure out how to make the solder stick, and made a mechanical joint by chamfering both sides. The plugs are still in there, since year 2000 I think.
Holy crap that was a long answer!
Dang it AJ, :BangHead: all I asked was for a picture!:BangHead:
:poke:
:rofl:
Seriously now,:thankyou:
I gave you one sentence, is it my fault you read the whole thing? lol.
I'm not buying a camera for you. And even if I did, I'd have to hire somebody to show me how to work it.
The last camera I bought was a Polaroid, with the self-developing pictures..... right after I got married forty friggen three years ago. Hyup, best thing I ever bought.
Gotcha, so my biggest issue besides my eyes burning is that the primaries are too small, which is why my idle speed screw is almost maxed out causing the transfer slots to be overly exposed. The way to correct it is to start drilling, or find a bigger carb...
Before I modify these throttle plates I will try to find a 1-11/16 bore carb in my stash. I will report back when I make it back and look.
Thank you so much for your help in getting me on the right track!
Not relevant to your carburetor issues, but there's not a damn thing wrong with your pappy. Back when he was doin things, there was so much zinc and phosphorus in motor oil they just cranked new cars up right off the assembly line and drove them out into the lot. Precious little time for break in on those assembly lines. There was hot testing on SOME engines, but nowhere near all. Most of them were busted right off once the car was completed. So in a sense he's right. At least the sens of how things used to be.
No, the throttle plates are not to small U have some other problem. U don’t need to drill them either. Kim
oldkimmer, if throttle plates are not to small (and that I dont need to drill the throttle plates to get more air in at idle) could you elaborate on what the other problems I may have be?
