Post your wheel and tire combos.
Not as nice as a lot your cars, but here's my '66 Valiant. I bought a set of 14x4.5" steelies and some Toyo 185/75s to put on them. The tires showed up and I realized they were gonna be way too tall for the fronts. Decided to keep the 13s up front and put a new pair of Uniroyal 155/80s on those. Scored a nice set of dog dish from a fellow boardmember to class things up a bit. Pretty happy with the stance, but I think want to drop the whole car an inch or so.
Car year and model
69 Dart Custom
Front
Wheel Brand. Cragar
Size. 15x7"
Backspacing 4"
tire size. 215 60R 15
Suspension mods none
Rear
Wheel Brand Cragar
Size. 15x8"
Backspacing 4"
tire size 225 60R 15
Suspension mod. None...yet
1973 plymouth valiant front
Factory mopar 14 inch steel wheels. Hankook 225 / 70/ 14 stock front suspension rear factory mopar 14 inch steel wheels Hankook 225/70/ 14 stock rear suspension. Hubcaps. Police Dog dish 9" inch hub caps
1m
Car year and model - 69 Barracuda
Front
Wheel Brand - Canterline AutoDrag
Size - 15X5
Backspacing
tire size - 205-70-15
Suspension mods - none
Rear
Wheel Brand - Centerline AutoDrags
Size - 15X8.5"
Backspacing - 4-7/8"
tire size - 275-60-15
Suspension mods - springs moved in to frame rails, stock wheel wells.
Lets keep a running list of wheel and tire combo. Its an often asked question.
Copy and Paste in to your reply
Car year and model
Front
Wheel Brand
Size
Backspacing
tire size
Suspension mods
Rear
Wheel Brand
Size
Backspacing
tire size
Suspension mod
Rear
Mini tub & spring relocate
355/30/19 tires 19x12 rims (50mm offset, but I have a modest narrowed rear. It’s just under stock A body width).
If you look at most 12” or 13” wide rear rims you will find more off the shelf rims will have around a 50mm offset.
Front
275/35/18 tires 18x9 rims 30mm offset
And I have different set I run
285/30/18 tires 18x9 1/2 rims 35mm offset
There are many different combos that fit on the front. It all depends on what your front to rear proportions look like afterwards.
There are a lot of so-called gurus on this site that like to repeat over and over what fit on their car. Just measure your own car and remember there is 25.4mm in an inch when doing your math.
if you need a plan to build a rear end for you car I can give you drawings (stock or tubbed) and even where to weld on things like sway bar brackets.
355/30/19 Just mini-tub your car. I don’t regret doing it. And it gives the car a proper stance and the pro touring look I wanted.
Personally I was looking at the possibility of running Michelin PS2 345/30-19 on the rear of mine. What front tire size do you have? Never mind... found your older post: 275/35/18; I am planning on that or a 285/35-18. Got to get it running and driving before I spend money on wheels and tires!
Car year and model 1968 Dodge Dart
Front
Wheel Brand Torq thrust T70
Size 14x7
Backspacing
tire size E70
Suspension mods
Rear
Wheel BrandTorq thrust T70
Size 14x7
Backspacing
tire size F70
Suspension mod
Front
Size 14x7
Backspacing
tire size E70
Suspension mods
Rear
Size 14x7
Backspacing
tire size F70
'68 Dodge Dart
The wheels are Jegs "SSR Star Wheels".
JEGS SSR Star Wheels | JEGS
15 x 4" in the front w/late A-body 10.87" disk brakes.
185/60 15 Firestones.
15 x 8" rear w/5.5" backspace--required due to big bolt pattern Yukon axle upgrade on 8 3/4" A-body rear. 255/60 15 radials.
Offset shackles & hangers. MP Super Stock springs w/1" lowering blocks.
Dazzler vision wheels
17x8 rear 0 offset 255/50/17 Nitto 555's
17x 8 front +30 offset 235/45/17 Nitto 555's
Drives like a dream and they are unique.
'68 Dodge Dart
How much do those wheels weigh, compared to weld draglites ?
73 dart
late 70"s factory ten spoke
15x7
4.25" backspace
235/60R15
front: qa1, firmfeel, pst,helwig, poly, extra long wheel studs
rear: hotchkis, helwig, poly, extra long wheel studs
