Johnny Dart
Nice clean body, V8, cleanest Candy Canes on the planet.
What's not to like ?
That's great advise! Thank you.i'd go $3500 and be ready to walk away. when you get car buying fervor, it rarely works out. i bet the "out of town" guy never materializes
You should think about this statement. It's not the buyers fault he into it more than it's worth.An update: the owner's asking price is $5000. He said he's got too much money in it to accept my offer.
NS, who isn't...only things i've ever gotten out of my cars is frustration, pain and unbridled joy. what i may someday sell it for doesn't even figureWay more into it than what you ever get out of it.
Right? I mean, he put money into it to make it road worthy and safe. It's not like he bothered to replace the broken antenna or the wheel well moulding.You should think about this statement. It's not the buyers fault he into it more than it's worth.
That's a helpful tip! Thanks!When you check the transmission fluid the trans must be in neutral NOT PARK! Mopars differ from other cars in that respect.
Looks like a nice western car...
Congrats on your a body. For tire the first thing I'd look for are 14 inch rims. Goes a long way in the future and improves handling. You have to buy the tires anyways. Take a ride to your nearest junkyard. Also plan on spending $1,000 - $2500 more before you get in good running cond. Find a good garage that works on old cars. Have them pull the wheels and ck the brakes and brake lines then have them change the trans fluid and adj the bands. Hopefully there is a drain on the convertor and check the adjustment on the kickdown lever. Also it would be a GREAT idea to have them swap over to a dual master cly. (a major safety issue). These things also have mechanical camshafts. So have them do a tune up (points/plugs) and adj. the valves set timing at 12 btdc. Also have them put a wrench on everything as you never know what's been changed on old cars. I'm sorry for all the work but this will at least get you a very good start. PS make sure the battery is always up to charge. And most important HAVE FUN.Okay! I got it for $3500 and I got her home without incident! Now the hard work begins... First order of business is to get new tires. We'd like to get white walls, but I'm having trouble figuring out what size tire to get since it has both 185/80/R13 and 175/70/R13 on it. By the looks of it, 13-inch tires are mostly trailer tires these days. Can anyone suggest a suitable size and WW tire that's under $70/tire? Where do you guys look for tires on these old-timers? Most sites don't go back to 1965. Thanks!
If you're not worried about keeping it stock, I'd consider doing a big bolt pattern disc brake conversion and get some 15" wheels for it. I just had a 225/70/14 tire go bad and had to order it. Just had to wait a day, but 14" tires are getting phased out too it seems. If you're going to keep the stock 13" wheels, take a look on the Discount Tire website.Congrats on your a body. For tire the first thing I'd look for are 14 inch rims. Goes a long way in the future and improves handling. You have to buy the tires anyways. Take a ride to your nearest junkyard. Also plan on spending $1,000 - $2500 more before you get in good running cond. Find a good garage that works on old cars. Have them pull the wheels and ck the brakes and brake lines then have them change the trans fluid and adj the bands. Hopefully there is a drain on the convertor and check the adjustment on the kickdown lever. Also it would be a GREAT idea to have them swap over to a dual master cly. (a major safety issue). These things also have mechanical camshafts. So have them do a tune up (points/plugs) and adj. the valves set timing at 12 btdc. Also have them put a wrench on everything as you never know what's been changed on old cars. I'm sorry for all the work but this will at least get you a very good start. PS make sure the battery is always up to charge. And most important HAVE FUN.
Thank you! If I switch to 14-inch rims will I lose the ability to use the hubcaps? Also, does anyone know where I can find this front left wheel well trim? I don't know if there is a nation-wide salvage search website. Thanks!Congrats on your a body. For tire the first thing I'd look for are 14 inch rims. Goes a long way in the future and improves handling. You have to buy the tires anyways. Take a ride to your nearest junkyard. Also plan on spending $1,000 - $2500 more before you get in good running cond. Find a good garage that works on old cars. Have them pull the wheels and ck the brakes and brake lines then have them change the trans fluid and adj the bands. Hopefully there is a drain on the convertor and check the adjustment on the kickdown lever. Also it would be a GREAT idea to have them swap over to a dual master cly. (a major safety issue). These things also have mechanical camshafts. So have them do a tune up (points/plugs) and adj. the valves set timing at 12 btdc. Also have them put a wrench on everything as you never know what's been changed on old cars. I'm sorry for all the work but this will at least get you a very good start. PS make sure the battery is always up to charge. And most important HAVE FUN.
I think I'd like to keep it stock for now. How can I find out what the original tire size was? Thanks.If you're not worried about keeping it stock, I'd consider doing a big bolt pattern disc brake conversion and get some 15" wheels for it. I just had a 225/70/14 tire go bad and had to order it. Just had to wait a day, but 14" tires are getting phased out too it seems. If you're going to keep the stock 13" wheels, take a look on the Discount Tire website.
13" tires are limited. You may need to just put on what is available.I think I'd like to keep it stock for now. How can I find out what the original tire size was? Thanks.
I think the car was originally light blue and was painted white at some point.Looks like that wheel was a replacement off a light blue car. I'd put on the biggest 13" tire I could find if you're not going to change the wheels.
