Backed chevelle out and remembered i have to bleed brakes. It has some. Just not much.
All us people in Pennsy look the same if your not from here!
Just looked the thread to see for myself.Wow just wow, cant even reply to this one.
"Sorry but that is just incorrect. It's always negative you are going further BEFORE TDC as you add advance.
For example you start at -10 initial add 26 more centrifugal as you speed up the motor and advance to -36 Before Top Dead Center."
Wow. Just wow.
You explained what he needed to know so clearly too. Even the distributor/cam vs crank angle.
The 4 and the 6 are marked as expected.Now here's a funny one.
We almost always see the initial timing refered to as Before or After TDC.
The timing marks on the AMC 360 in the 80s (and I think 70s) have a capital A stamped at one end.
But it doesn't stand for After. View attachment 1715732645 View attachment 1715732646
I know my Polara the marks on the dampener are a PITA. It’s got 3 notches on the dampener, AND the marker on the timing cover looks like the one you have aboveThe 4 and the 6 are marked as expected.
But on the v-8
A is Advanced.
Tricky!
So, they put a concrete plant where the asparagus plats were supposed to be? Did it grow OK? What kind of fertilizer do you use on that?I didn't even know what asparagus was until I went to work a flood control channel job on the Tijuana River.
The pad they cleared for our concrete plant was right in the middle of the asparagus fields in the river bed.
Just took a dozer and pushed all that grass up in a pile
I know I read a LOT of Dan's posts and articles on slant 6 and lighting in the process of building mine. When I couldn't find an answer and asked a question he almost always showed up with an answer. Don't know that I have ever found anything he said to be wrong. As ide from many years of experience, he often references tech documents. i.e.- he ain't making **** up. At least for those 2 topics, till proven otherwise, I would consider his advise 'the final answer'.Dan even gave him a red x
It's Tittie Tuesday!
Looks good timHey you guys. took a while to get caught up. Installed my new top yesterday.....
Hows your Dart coming along?Looks good tim
Haven’t touched it since March. Had the baby, then my grandfather died, then I went on Active duty orders.Hows your Dart coming along?
So what have you been doing with all your free time?Haven’t touched it since March. Had the baby, then my grandfather died, then I went on Active duty orders.
What free timeSo what have you been doing with all your free time?
I am working on the 66 everyday. I am determined to get it done and on the road.....THEN get going on the Satellite...................Haven’t touched it since March. Had the baby, then my grandfather died, then I went on Active duty orders.
