Any LowBuck but STRONG overdrive option?
GM 200R4 or a FORD AOD. I think both have been used with only a crossmember mod to fit and a plate or bellhousing. IIRC the tunnel was OK with maybe 1 dent to clear some bump. An electric lock up will give you about a ~250 RPM reduction at speed.
Funny you mentioned the Ford AOD. I do know a guy that did that behind his SBM. I don’t know what mods were done/needed. But he does like it very much.
if you swap in the A998/999 ratio box with a lock-up, the new low gear of 2.74 is 11.8% lower than the 2.45 of the 727. This would allow you to drop that same 11.8% out of the back.
Post #1 says you have 4.10s so, now yur down to 3.55s.
Ok 4.10 x 2.45=10.05, and 3.55 x 2.74=9.73; close enough..
Now for second gear; your current combo is
4.10 x 1.45=5.945, and with the other it would be
3.55 x 1.54=5.467, that's doable.
Your current combo with 27inch tires will do 65=3350 at zero-slip, possibly as high as 3500 at 4% but more likely, 3450 at 2.5% slip on flat level,hard ground.
The new combo will get you 65= 2900 in lock-up. that is a total reduction of about 16%.
The Mopar overdrive unit has a ratio of .69, which is a reduction of 1 minus .69=.31 or 31%; and that would bring your current 65=3450@2.5% slip, .. to
65=2311 in lock-up.
Will the A998/999 trans take 400hp?
With a few affordable mods, yes.
Except for requiring a longer driveshaft with a 904 yoke, a different flex-plate, and all the original KD mechanism, this is a bolt in.
credit to RRR for first mention in post #9
Getting a little off track here RRR as this is far from a "low buck" option. @Treblig is running one too I believe. Sure, you need a mount modification but the body fits. The Mopar overdrives need the body modification.
I didn't bring the damned 200 up. I'm right on track because I reminded them the 200 requires cutting which is NOT budget friendly. Next.
Yeah and you clearly said it would not require cutting.....said you ran one. So what is the argument?
F
Like others have said. I think it can go both ways. A lot of modifications to the transmission to make it fit without modifying the body. Seems easier to me to just modify the car.
It's just tight as a virgin on prom night no matter what you do. I think even modifying the cross member on a stock vehicle with a 904 would have it's advantages.
While it's apart, I actually think about doing it to my Barracuda for a future upgrade. It aint quite that rotten but it does need front floor boards.
That's what I figured. I don't have the numbers on the thing but he told me it's a lock up 727. I'm probably confused cuz I read something about being able to take a lock up converter Indo power to it but that was probably for the overdrive 500 or 518
There is a hydraulic lock up 727 non overdrive.
Easy to spot just pull the torque converter the lock up model uses a different input shaft. The lock up shaft has no splines on it for the approximately the first inch the non lock shaft will have full splines.
I am having one built for my Barracuda later this year, trans Guy just found a core for the project. Should not require any major metal work to install. We will know more after I get my hands on the core.
Yes but the ratios are still 2.45-1.45-1.00; so about the best rpm reduction you can get will be 2 to 4% depending on cruise rpm and power required to push your vehicle thru the air. With 4.10s, Ima thinking closer to 2%, on account of the rpm.
BTW;
I wouldn't recommend the 3+1, A833; the od gear has only about 18/20 teeth on it and is, in my experience, easily shattered. Even my stock long-block 1973 smoggerteen blew one up when I put a lil too much power into it. My 367 blew two more up.
That overdrive is strictly for cruising in;
it will not survive any shock-loading.
Though simple enough to spell, Good and Cheap are Two words that don't often fit together very well.
Cheap is also a relative word...One man's Dollar is another's Hundred.
Personally, I'd get one of these NEW Ready to Go Proven Performers that'll fit your specific Tranny/Engine combo and be done with it rather than dicking around for God-knows how long trying to Sav-A-Buk when you'll ultimately end up probably spending the same amount and having an inferior product....
Just My Two Cents and that and another $23.98 will get ya a cup of Starbuckles.
Automatic 3-Speed 727 18" Tailhousing - Gearvendors
Expensive as heck option but it ma suite the need.
Thanks can not justify that insane expense for MY purposes.
AJ, I am OK with the trans ratio's as that is what I currently have with my non lock up 727. My current 727 is gett'n tired and as long as I have to replace it I figured that I would spend the money for a lock up 727 and converter.
442 HP, 340, 3000 stall, 3:55 ratio with 28 in tires.
With the lock up Im guessing the my engine rpm @ 60 mph will be around 2600 rpm.
Your thoughts?
Sorry to step on the thread.
i'm with AJ...904 with low first and second gear.With that hp in an A body you should be able to run
a 3.23 rear gear which will be the same as 3.6:1 in first but final drive is 3.23.
The fly in the ointment would be if you had a long duration cam which would kill lo rpm torque.
What cam are you running?
