440” small block, pump gas, street car...
dusterdoug
Tracy, CA
Cam is a bit rowdy, but FUN to drive around town.
Never in my 40+ years of running Mopars have I ever heard of a SB 440... Guess I learn something every day
It’s been a possible combo for a long time needing a big bore. 4.17 stroke X 4.100 bore is an example, (4.220+ bore size able race block needed here ->) 4.2 bore X 4.0 stroke is a 443. 4.07 X 4.25 stroke crank no longer available IIRC = 442 cubes.
IF you have the big bore small block, the one that is able to be bored to 4.2, then use the 4.25 stroke crank, you’ll end up with an incredible 471 cubic inches.
The current problem to achieving this (IIRC) is now the crank as the block can be a Ritter block for the bore size. Then to properly feed this size engine, you have a cylinder head problem. It only gets so good.
Yep, big inch small blocks have been around awhile now. Mine is as follows...
440 small block (4.25 crank/4.06 bore)
R3 block
Rod Bloomer stroker kit
10.6:1
Indy 360-1 heads
T & D rockers
Indy intake
1025 cfm 4150 carb
Comp solid roller:
.700/.672 - 270/276 @ .050 112 center
Holy Batman......now i understand what you mean regarding the cam.....some pics from the engine assembly? Did you dyno this beast?
Michael
Yes, it needs a smaller cam, will do that someday along with EFI...
No engine assembly pics unfortunately. My dyno will be some 1/8 mile timeslips this fall!
R3 block
10.6:1
Indy 360-1 heads
T & D rockers
Indy intake
1025 cfm 4150 carb
Comp solid roller:
So it's a solid 14's car? :lol:
Looks real good in the pic.
Sweet, I like it.
Cam is very big for that compression, and being on a 112 will need a ton of convertor to get it to leave well.
But, super sweet, looks like lots of fun!
With a cam like that, I don’t think he cares about a the few thousand lower rpm’s. LMAO!
I wouldn't doubt that it's pretty stout down low, that 4.25" crank is going to help. His cam's duration is bigger than mine, 263/271 @.050, 108, .711/.719" and I'm running 11.2-1 compression. My 434 is a monster everywhere.
I'd be willing to bet he could run almost, or maybe 1 more point of compression and be okay on pump gas.
An acquaintance of mine had a 471 (edit, small block 471)in a nine second street 71 demon, made a couple of Mopar magazine covers.
Also built a 501 (or was it 502?) Small block. That one was a little too far over the top, didn't last long.
He's now on his 2nd or 3rd demon challenger, not counting a couple hellcats.....
