Stop in for a cup of coffee
Yup, neither vehicle is plugged in. So i did the right thing and went out in my jammies and got em plugged in. Extension cords are not bendable in this weather. Could play billiards with them.
Yup... I get that. Had a guy shatter a pair of boots up in Northern Quebec because he failed to put them inside his sleeping bag. Materials get weird at those temps
Kind of like Velcro becoming explosive under 100 percent oxygen
Its container day!
Like dad used to say, "drier than a popcorn fart" I need to fire up the humidifiers around here. Whenever we update the air handler system I hope to ge one put in the ductwork. It wouldn't work now because the forced air portion of our heating system doesn't run until the outside temp get down around zero and the hot water side can't keep up.
Hey you ever get the trans adjusted?
Been busy with work and family stuff to get back to it. I think the catch spring on the transmission side cable end is not engaged so the rooster comb is pushed fully back to reverse. Which means I'll probably need to drop the pan to get it corrected from underneath. I'll try going through the neutral safety switch first though.
These trans are a PIA. I have one for the cuda also.
I think that's where my sore throat is coming from. I keep my place set to 64... my SiL keeps his around 70.... super dry and static is crazy
E10 is $3.12 at the Casey's convenience stores all over town.
