Johnny71dusty
They don't say much but they say 80-150 psi . They don't really go up unless psi over 80 either
Step 1: Admit that your plan is 'tarded.
Step 2: Take the rear springs off. It's easy. You don't even have to pull the axle. Just a jack and stands at a minimum.
Step 3: Steal another car and take your springs to a leaf spring shop.
Step 4: Tell the leaf spring shop you're a recovering 'tard and need to increase the rear ride height by "X" amount of inches.
Step 5: Drink Mountain Dew while spring shop does their thing.
Step 6: Go home, turn back the clock, reinstall newly modified springs.
Step 6a: Ditch stolen car. It was probably a Kia anyway.
Step 7: Pull retarded pickup shocks, install proper shocks, possibly longer ones depending on "X" from Step 4.
Step 8: Realize that height and load are controlled by springs, not shocks. Shocks are damping only.
1977 called, and they want their ignorant air shocks returned to them.
1977 is right on! It looked cool but rode like a truck and handled even worse.I would get the right size wheels and tires on it and forget about the air shocks.
We need to hang out sometime. You can tell me tales about selling tools, and I can drink Mountain Dew.
Lot's of stories!
I'd don't check unless my car sinks . Takes 2-3 weeks and drops 2-3 " lolAir shocks hold such a little volume of air, just checking the pressure with a gauge can let a lot out.
They're brand new leafs , brand new shocks not trying to get my height any real difference than most other dusters lol . This is height I want and need to keep . Issue is they go low and if I load trunk up with stuff they sag easily too . My power tour Load wasn't even that much stuff and sagd the rear badlyStep 1: Admit that your plan is 'tarded.
Step 7: Pull 'tarded pickup shocks, install proper shocks, possibly longer ones depending on "X" from Step 4. Sell 'tarded pickup shocks to some 'tard. You don't need them because you're not 'tarded any more.
Looks like plenty of room on the outside. Where do they rub? 255's here on 15x7 with a 4.25 backspace. Just an extra leaf on mine.They're brand new leafs , brand new shocks not trying to get my height any real difference than most other dusters lol . This is height I want and need to keep . Issue is they go low and if I load trunk up with stuff they sag easily too . My power tour Load wasn't even that much stuff and sagd the rear badly
You better re-read the installation instructions. You are doing something wrong if you are having issues with both. We would spray them with soapy water and look for bubbles. You can also take them off, air them up and dunk them in a bucket full of water.But yes my dart air shocks leak the exact Same way
Wrong offset wheels.72 dart , 8 3/4 rear , old style leaf spring inboard kit which moves leafs in like 3/4 " . My 255/70/15 cooper Cobras barely fit . Rub frame rail and inner trunk well on hard turns where body rolls . Not taller talkinf about clearances here . I'm talking about these air shocks not holding pressure and leaking down over 2-3 week period.
Again done this over and over . It takes weeks 2-3 to drop . The shocks say 80-150 psi . They don't even rise unless 80-90 in them most I've ever gotten is 115 . They hold for 2-3 weeks . I can't even get 150 in them but 100-115 and they leak down 75 ish over 3 weeks and stop .You better re-read the installation instructions. You are doing something wrong if you are having issues with both. We would spray them with soapy water and look for bubbles. You can also take them off, air them up and dunk them in a bucket full of water.
They what they offer lol 15x7 rallye 4.5 back space .Wrong offset wheels.
Same as mineMiss spoke
Both my rear wheels are the same
On both my cars my 71 duster with 275/60/15 . No leaf spring inboard kit , rub quarter if car is too low .
72 dart with leader spring inboard kit , rubs frame with 255/70/15 on hard turns
Again issue I'm complaining about these Monroe shocks not holding over 2-3 weeks . And why they don't rise unless at 80 ish psi and come with instructions say 80-150 psi . And again it's not the o rings .
Wheel Vintiques 61-5754044 Wheel Vintiques 61 Series Chrysler Rallye Silver Wheels | Summit Racing
I waited for nearly 2 years for the 15 x 8 in back order from anyone who sells those wheels. 14" wheels are dumb . 275 or bust lol . Also the shocks leaking down have nothing to do with my tire choices.Not for this guy, but for others reading this post. 5 on 4" bolt circle,
The car was designed for and came with a 14 x 5.5" rim. 8" section width. a 25" tall tire. D or E-70 x 14 or smaller.
We are trying to fit a 15x7" rim with a 28-29" tall tire. 10.8' section width. 4.25" Back space. 275/60-15
Fitment charts say this won't fit, true.
Tire is too wide for the rim, should be 8".
Fitment charts recommend for this car a 14x7 or 15x6 max for fit. With the 4" bolt pattern ( limited rim selection)
Like trying to put 5lbs of s**t in a 1lb bag.
Biggest problem, wrong tire and rim offset (bolt pattern doesn't help either.)
Solutions.
(1) If you have to have that size tire/wheel you have to $pend. Offset spring kit, possible inner wheel tub mod. bolt pattern upgrade.
(2) Easiest, smaller tire. The 7" rim is designed for a 235-245mm tire size 9.25 section width, 26" tall
