Here's a cool little 273/292 build for the 273 guys.
273
Ontario
The 273 Build That Doesn't Suck​
Forget The Little Engine That Could. This Is The Little Engine That Does!
WARNING: Reading this article might cause you to giggle uncontrollably with excitement. It might lead to sleepless nights and neglected work-hours spent planning your own 273 build. It might have you scrounging vintage salvage yards, the classifieds and maybe even strangers' back yards looking for neglected 273 cores. It might even lead you to abandon all rational engine building protocol in the quest to create your own dare-to-be-different scream machine.
We are not responsible for any of this. However, if you choose to build an engine like this, we'll be right there to help you build it.
A few months ago, Chris Sockriter stops into our shop with that glint in his eye and a plan in his head to build a hot 273 for his 69 Dodge Dart. Now if this was 1965 and the 273 was still a serious D/Stock contender, we might have been just as excited as Chris to build this engine, but the fact is, MOPAR's tiniest small block is just that- tiny- and as anyone who builds or has had an engine built for them knows, bigger engines make more power for less money. In other words, why build a 273 for power when you can build a 360 that will make more power for less money? While you're at it, why not build a 408? In comparison, they're even cheaper than 360's when it comes to producing power for pesos.
But like we said, Chris had that glint in his eye, a plan in his head and money in his pocket and all of them were targeted to build the 273. So we kept listening. And that's when things started to get interesting. Turns out Chris didn't just want us to build a hot 273, he wanted us to build one with a hair dryer- aka- a turbo (or two), for some stick-shifted silliness in that Dart we mentioned earlier. Now we started getting that glint in our eye too. This could be fun. Sure, the 273 is still small but throw some turbos at it and it gets quite a bit bigger. Factor in the advantage that Chris already had the engine and that its factory forged crank is plenty tough for boosting and beating and the higher costs generally associated with building small engines might not be so high. So we devised a plan to build a simple, stout, small block that's just a huff-job away from becoming a hero.
Building For Boost
With the plan established that this was going to be a turbo engine, we got to work on prepping and building for boost which in this case, like every case, meant first building a solid and excellent performing naturally aspirated engine. To do this, we spec'd out a package that included a mix of tried and true components along with some creatively applied out of the box thinking and parts selection along with our requisite high accuracy prep, machining and assembly procedures.
The Foundation
The Block
Since everything is built to go on or in the block, we started there. From the beginning we were concerned about the 273's small bore- things like bore shrouding, air flow and even basic piston availability were major considerations; custom pistons for example can add huge costs to a build. As it turned out, we had little to be concerned about. Here's why: sonic checking the walls on this particular 273 revealed thrust side cylinder wall thicknesses of about .280. Better yet, core shift seemed non-existent on this block because the numbers were consistent from front to back in both banks. If nothing else, this solved our piston selection, material and price issues because we could safely bore the block to stock Chevy 305 size which meant our piston options grew almost exponentially while the price point dropped with the selection and availability of the much more common pistons.
The Crank
Like we mentioned before, this was almost a no brainer. We know from experience the factory forged steel crank can take a beating thanks in part to its robust construction method, material and relatively short overlap. Provided it was in good condition, this would prove a near perfect part of this build. Fortunately, the crank was in beautiful shape. Done.
Rods
Yes, Chrysler's factory forged steel connecting rods can be excellent choices for high performance engines but the reality is that once you factor in the cost of reconditioning, new, forged steel performance rods are a better and more economical choice. We used SCAT I Beam rods.
Pistons
Knowing we were gonna get blown dictated several custom design parameters be built into the pistons which is why we went with custom designed PIE/JE units. Even with the custom design however, the more common bore size kept costs within reason for this type of build.
Camshaft
One of the great things about turbo engines is their excellent street manners vs performance potential. Turbos make great power while offering unmatched drive ability. Getting blown is awesome! With this in mind, we selected a reasonably mild, off the shelf grind from COMP. It specs out with 218/226 Duration @ .050, .525 I/E lift and it's all built on a 114 LSA. This is a cam we knew would make great power in naturally aspirated tune but also make the most of what the turbo has to offer.
Heads
This was almost as much a no brainer as the crankshaft or conrod selections: we went with the EQ Iron Magnum heads. When it comes to bang for the buck these things just can't be beat. EQ's key durability upgrades that addressed the Magnum's short comings combined with an LA style manifold bolt pattern make these heads outstanding, economical performance pieces. The iron construction also make these perfect for power production and long term reliability in a turbo engine. For our part, we added our exclusive Stage One Porting which includes upsized intake valves and flow bench tuning that help unlock even more power potential. Throw in a set of our adjustable roller rockers and this part of the combo is good to go.
Intake
An Edelbrock Super Victor will help handle the deep breathing induction duties. It will be drilled and set up for EFI once we go boosted. Until then (and for dyno testing) we'll use a 700 cfm carb.
Oiling System
A Melling standard volume pump is all we need to keep everything moist. Remember, staying lubed is a very important feature when you're gonna get blown.
Prep, Machining & Assembly
The reality here is that for most people, machining isn't all that interesting and we get that, so we won't bore you with details here except to say that exciting or not, proper machining is critical to an engine build's success or failure on the dyno, the road or the track. Both power production and durability are greatly affected by the quality of the machine work. With this in mind, all you need to know is that we spent painstaking hours, the way we do with every build, inspecting, cleaning, machining and prepping every element of this little 273. From machining and assembly to inspection and cleaning to fanatical detail of each and every tolerance, we checked everything to make sure we didn't miss anything.
Dyno Time
Let's face it, you probably skipped to the dyno sheet before you read anything else. That's cool, we do that too. In that case, you already know the little 273 made 360 bhp and 355 lb-ft of torque. Stout numbers indeed. Naturally aspirated, this works out to about 1.3 bhp per cubic inch which means this little beast is pretty efficient at sucking air, mixing it with fuel, slamming them with spark and blowing the whole combustive cocktail out the exhaust. And it sounds sweet doing it.
So what's next. Well, we think you have a pretty good idea by now. Soon we'll pour on the boost and see how many more horses we let loose. In the meantime though, Chris is getting ready to drop this little bomb into his Dart and drive it as is for a while. We know he's gonna have blast with it but we can't wait to get those turbos installed. Once they're on, the suckin', squeezin, bangin' and blowin' is going to get really good.
Wish I could find the dyno sheet that article mentions, a 292 with a 218/226 .525 114 cam making 360 hp 355 tq ain't too bad
I would say it’s a pretty optimistic dyno. That cam and let’s say 8-1 compression I would say they are lucky to break 300 hp. Kim
I like how every time something doesn't fit with peoples preconceived notion it must be a lie.
Why would this engine builder lie, is a 360 hp 273/292 gonna sell them a ton of heads and crate engines, sure they could be.
Before you go get all excited about a 273 buildup, get a total cost from that shop to duplicate that build, and compare that to your local pull-a-part $500 360 magnum, that will make that power plus more torque with nothing but a china 4 barrel and a cam swap.
Is the pic actual or a "representation"? Claims to be running a Super Victor intake. That is not. Probably more to the story, but, dyno numbers have been called out too. Good for them for doing the unpopular thing, no matter the outcome.
360 hp that's nothing compared to Jim's 273 build, 470 something as I recall at upwards of 9-10,000 rpm. N/A at that. lol
I see no reason this little engine couldn't make 360, when we got guy's claiming 450 with a mediocre 360. lol
Did you put that up in the magazine build section?
My answer to your quoted reply and question is;
“Because some people are dishonest, don’t calibrate their dyno, give a “Best used in” application, kind of stuff in addition to what others have experienced at their dyno operators machine. Sometimes, things look to good to be true.
This forum has had several head porters and engine builders that have had their work on display and for sale here only to be exposed as less than advertised and sometimes in a big way. So trust is diminished and demand for accurate information is demanded before belief is obtained. Even down to items for sale as simple as an intake manifold with close up pictures and up to engines with running video of it which can also be misleading.
@replicaracer43 has shown us in the past and a shout out to his philanthropic hand helped a fella here big time.
Sometimes, many times, when something looks to good to be true, it usually is. Now I’m not calling this engine builder out on anything. But I’m not buying it or purchasing it. I’m going after the larger engine and if it is a create engine, it’ll be a BluePrint from member @Johnny Mac how can tell you all about there operations & results. Johnny Mac has been nothing but upstanding, helpful and gracious.
(I’m also happy to have helped in his B body project just a tiny bit.)
His company is a trusted source.
PIE? Same rep? Ahhh, No. Not from what I have read. Sorry.
Near flat on the hp/tq....
305 bore is what 3.73, from 273 3.62?
Eq's are overkill and a terrible choice for that motor if broad torque and drivability was the goal. Motor like that is a turd under 3800 rpm, needs a stick or big convertor and basically redline 100' to the traps.
Why don't they ever build a 273 at .040 or .060 over with a decent 500 lift cam and ported 1.78 valve 1.50 273 heads in the magazines?
Because they're selling you products. They keep the purest hanging on when they introduce a stock Parts build 'once in a blue moon'.. the rest of the time they're selling you parts.
Of course these heads are a terrible choice for this small bore engine but that's who sponsoring and buying ad space this month.
I agree most should go with a running 5.9l magnum but it's cool to see other builds and if it was all about money we'd all be running Chev's.
In today's world, yes. I've seen, been in some small cube potent builds back in yesteryear, even a couple 318's. lol
A Ford 289 in a Mustang at Hot August Nights a number of years ago hanging it's frontend in the air off the stoplight. lol
Juice works wonders. lol
They need to use tune port nitrous with a 250 shot to each cylinder with Uncle Tony driving.
Have someone bump the distributor a little too far Advanced before it takes off and watch the show
Correction: Here's a cool little 273/292 build for the 273 gays.
I see you're only building a little 416, what's that all about.
Why build such a dinky bore engine with a long arm. lol
Someone needs to sawsaw the front yoke in half and replace the seat belt bolt with a zip tie LOL
matt steins 235/273 super stocker , with 273 heads, stock stroke, stock carb, stock port volumes, runs SS/K, seen video , it ran 10.20, @ 130 mph. 66 valiant . impressive,
I like all the Mopar small blocks. Anyone that doesn't I question their "manhood".
