Oil filter adapter gasket location
Thanks. I was actually shopping that part number in google searches but Brewer's doesn't come up very high on the list in google.
I'm still looking for the Fel Pro number. Can't seem to find it. It must be a secret because everyone that sells them doesn't picture the part number.
Here are the copper washers that I use between the bolt head and the adapter, instead of the fiber washer. I've never had a leak since I started using these. You will need to hone the ID of them out just a touch so they slide on the bolt easier.
Just to add some P/N info to this thread. Mancinni Racing has these gasket sets listed . The MP (P5249320) set is out of stock. I could not find a listing for it at Jegs, or Summit Racing. Fel Pro does not seem to have a complete set.
The other complete set is Superformance, and the P/N is SFP 340-K5
Dave
Looks like he gave you the link:
Try the Mopar Performance # P5249320 Brewer has the kit with the gaskets and a new bolt with the offset oil holes. That looks like the way to go as a upgrade. Brewer's Performance - Mopar A833 4-Speed Transmission and Component Specialists
Thanks for the link. I know yours is an old post but it looks like Brewer still sells the gasket and bolt kit. That upgraded bolt is a lot smarter than the original that would twist and collapse easily.
I should have mentioned in my previous thread, Mancinni Racing has the gasket kit, with the bolt also, P/N MREHFOFB-1 @ $35.99.
That Amazon price for the gasket set is not that bad, remember that's the delivered price.
Dave
I’m sure this has been posted somewhere before but I just bought an upgraded bolt that IS the correct length. I’ve read Mancini’s bolt is a tad too long and the head is not the same size as the crummy oe bolt.
Fast Fish Auto from Kannapolis, NC makes these. He may even be a member here.
Small block Mopar 318,340,360 oil filter adapter bolt | eBay
Small block Mopar 318,340,360 right angle oil filter adapter bolt. This bolt is NEW and made in the USA with USA 4140 steel. This bolt is for the oem cast iron and aftermarket Mopar performance oil filter adapter that require the longer bolt. Under head length is 2.950 inches.This bolt is much stronger than oem bolt and will not distort in the oil hole like the factory bolts did. This bolt is absolute premium quality fit and finish. Email with any questions you may have. Shipping price to US address only.
Glad I saw this, I'm sick of oil filter yoga.
Serious question: since they use the same filters (Mopar 090), would the 4.0 Jeep 90 degree adapter work on a Magnum 360?
