My 422 smallblock build
BTW, you can check to see if maybe your shafts have the oil holes in the correct location while the engine is in the car.
Get whatever cylinder you want to check on the seat with the correct lash. Pull the adjusters out of the rockers and stick a small pick or pin or whatever you can find that will fit in the hole.
If it goes in and hits the shaft you know the holes aren’t lined up. That’s a quick and dirty way to find out if at some point Chrysler fixed the issue.
I figured it out one day by sheer accident. I had the rockers off but I had the number one rockers on thx shaft. I had the adjusters out because I was probably changing them out after killing some of them.
I still had the stands on there with the bolts in them so the rockers were where they would be on the engine.
I was walking to the back of the shop and the rockers just started to turn on the shafts and it caught my eye. Then I noticed, because the adjusters were out that I never saw the oil hole.
I couldn’t believe it. So I spun the rockers on the shaft many times to verify I didn’t just miss the holes.
That’s when I pulled the rockers off the shaft, put some bluing on the shaft and put the rockers back on and put it on the head.
Then I stuck a scribe in the hole to mark the shaft.
And they were off not only left to right on the shaft, they are off radially around the shaft too.
Like I said, they may have corrected that but I’ve not found that yet.
Do you use something like a bent wire to go in the hole on W2 rockers with the outer hole plugged? I probably should have checked mine.
I have done it on 273 rockers, but it was easy with the hole all of tthe way through to the outside.
I don't know if @Rocket is still making the shafts. If so, it would be nice if we could get him the correct hole location for W2 shafts.
I have a set of his shafts, and they are nice.
The geometry was set up by Mike at B3.
Do you think longer pushrods would cure the overheating? Or could there be an oil flow problem due to improperly located oiling holes in the shaft?
My experience with W2 rockers, is that they DONT oil the pushrods correctly IF they are that far away from the adjuster. Went through this exact scenario 4 or 5 years ago on a W2 340 I machined for a buddy. I showed him how to measure pushrod length after the engine was assembled, but he mis calculated the exhaust pushrod length. It burned the tips exactly like yours. I measured and ordered the 2nd set, and no more problems. Been beat on heavily since, lash hasn't moved in 4 years at least.
could you do a similar mod' to the 'banana' grooves on some shafts? just add grooves from the pushrod oiling holes to where they'll align with the rockers to correct the misalignment and provide adequate pushrod oiling.
neil.
Brutal. It's good that you caught it early though.
Thanks for the reply and pics. Those look like the same Smith Brothers pushrods that I have.
Do you guys think that the adjuster being too far through the rocker is restricting oil to the cup? And moving the cup closer to the rocker will prevent the overheating?
@9secRR , are you running different length rods for intake and exhaust? Also, how much side clearance are you running on that setup?
When I set mine up SM heads with Mikes kit, I set the oil band in the adjuster centered on the oil hole in the rocker, did a sanity check with air and tightened the nut. Then I checked my pushrod length and ordered.
Side note, I can say that with full time oiling and a .080 hole feeding both heads it's like a fire hose, still way too much oil up top. Expect a mess if you go to check how much oil you're getting to the heads.
I’ve had success putting grooves inside the rocker to connect the machined groove in the ID of the body to the pushrod oil feed hole on rockers where the distance between the two was fairly long.
I had (probably still do but I haven’t seen it is fair bit of time) a right angle scribe I could sneak in there.
The NIB shafts I have are P4120589. The date on the box is 2002 but who knows when they were actually made. I have some TA shafts. Let me run out to the shop and I’ll see if I can find them.
The TA shafts I have are P357786 I think. The 8 may be a 6. Either way I believe them to be TA offset shafts. By offset I mean the oil holes not the mounting holes.
I’ll lay one of each side by each and see if the offset is the same. And yes, I’ll take a picture.
As the picture shows, the oil holes are in EXACTLY the location.
The upshot is the oil hole in the rocker NEVER EVER lines up with the oil hole in the shaft.
For the system to work the pushrod length must fit the Chrysler dimension AND when the valves are on the seat the pushrods and adjusters must get full oil flow and pressure.
My trusty machinist rule says the TA offset is .500. IIRC the W2/5 offset is .750 although I’ve seen some T&D rockers at .625 I think.
At some point in your program if you make enough power and rpm you will be forced to relocate the oil feed holes as I lined out elsewhere.
And I forgot to mention that I always mark each rocker for its location and then I know the hole in the rocker lines up exactly with the hole in the shaft.
If you get the oiling to the adjusters corrected you can run 360 on the seat, 1k over the nose and turn 9k. I know that because I’ve done it.
Until I see otherwise, any W2 shafts have the oil holes in the wrong location.
Thanks! It is a shame that Mopar did not relocate the holes. It would have been a simple operation.
It looks like I may have a winter project.
I agree with keeping the rockers where they are. I ended up with 2 different types of W2 iron rockers for the intakes. I bought/sold rockers from 3 sets to get equal valve lift on all cylinders.( within .005") I measured for every pushrod and so they too are cylinder specific. I don't have a lathe, so I cut them a bit long and then squared them up on the tipping side of the valve grinder.
pushrods are the same length. Not much side clearance, I can’t remember the # but it’s not much.
Ordered new pushrods from Smith Brothers. Ended up being .150” longer than the first set. Which is coincidentally the same depth as the cup in the pushrod. I suppose it’s possible that I measured overall length but told them effective length. Anyway, got everything installed and adjusted properly.
Now I’m working on the tuneup. I feel like it’s lean at at very little throttle but everywhere else is pretty close. It comes on immediately with the mash of the pedal with no hesitation and pulls hard past 6k.
Currently 20* initial, 34* total. Idles at 950rpm with 9 inches of vacuum on 93 pump gas.
Give me your opinions on these plugs. Autolite 65s.
Look at the center electrode. It’s got too much heat in it. I’d start by getting some timing out of it.
Where is the 34 total all in at?
It ain’t happy for dang sure.
The total timing is all in at 2200. Distributor has 2 of the light springs in it but I have other springs coming from Mancini to slow the curve down. Probably shoot for around all in at 3000 and go from there. Currently has a 6.5 power valve but I might try a 10.5. Its got a lean surge when the throttle blades are almost closed. Feels like “fish biting” when going down a slight grade.
That’s why the plug looks like it does. You have too much timing around and below peak torque and maybe just enough at peak power or you could be a little retarded at peak power.
One of the things to look at when checking your plugs is to compare the sharp edges of the ground strap and center wire of a new plug to what you see on a used plug.
When you see the sharp edges getting rolled over like that (or worse yet is when the side of the center wire is melted) the plug has too much heat at relatively low power and load.
If it’s getting after the ground wire that’s usually too much heat in the plug and high power and load.
There is a thing called “spark mark” (I suppose there is a text book name of it but I can’t recall it right now) and it looks like tiny little pock marks on the top of the center wire.
That is a good thing as that’s an indicator the ignition is nice and hot. I know at one time and it’s probably is still so that part of what helped get the spark started was the center wire would release molecules at ignition and that made firing the plug easier.
The issue was and still is how long the plugs last.
To that end you had three major spark plugs on the market when I came along. Champion, NGK and Autolite.
I put them in that order because Champion used the softest material in the center wire. NGK is in the middle and Autolite is the hardest material.
Not trying to go full AJ but this is the first time I’ve seen a good picture of a plug like yours on FABO so I think an explanation might help some read plugs not better but with more depth or whatever.
At any rate, the Champions to this day are still the softest and will need to be replaced sooner than the other two. Of course the Autolites will go longer than the other two.
If you are ignition deficient the Champions can help with random miss fires and such but they don’t last as long.
And because people generally don’t do tune ups frequently enough they lost performance by leaving the Champions in too long. Of course switching to an autolite made them last longer but with a weak ignition you can lose performance. And the emissions can go up.
And to finally wind this up, with the new stuff so crowded and cramped and because most people don’t check their oil and change it frequently enough just like the plugs rare earth metal plugs go in.
That stuff is harder than the hubs of hell. That’s why they can go 100k plus miles and not really lose much.
For what we do those plugs are a waste of money. And they are harder to fire. If you run points it’s noticeable. Even the much ballyhooed HEI is not enough energy to fire the plugs with rare earth metal construction.
Do guys do it? Yes. Will I do it? Nope.
Edit: I forgot to mention that the rare earth metal plugs use a very fine center wire to help get things going. A fatter rare earth metal plug would be much harder to initiate a spark. So they use a fine wire center electrode.
And fine wire plugs are not new. We used them in 1972 on dirt bike stuff. Before that even because one of the first things my dad did was switch to fine wire plugs when he bought his first two stoke which was 1970 I think.
They were fine wire but not rare earth metal and it for sure helped with the weak ignitions back then.
i tried some ngk platinum tip plugs back in the late 70's when they came out on a honda 400/4 i had (was still into bikes then). i used to work that bike hard and the platinum tip plugs didn't last. 2 melted the tips off after a couple of weeks. i returned them and swapped them for 2 sets of normal ngk's (they were half the price of the new fangled ones). i've stuck to normal ones since on cars and bikes.
neil.
The plug may not be new but not that old either. For oiled up plugs, check valve stem seals, worn valve guides, worn/broken rings or possible leakage past the intake gasket.
Pulled the intake last night and it looks like #8 was sucking oil from the valley. These Cometic gaskets were only .031” thick and I was skeptical about them sealing well to begin with.
Ordered a new set of .062” gaskets from Summit so should be back up and running soon.
Update
So, since the last post, I changed out the .031” Cometic intake gaskets to a set of .062” Mr. Gasket and that solved my oily spark plug problem. I’m guessing that the block, heads, and intake have been machined so many times over the years that tiny machining tolerances have added up to a less than perfect mounting angle. But, she appears to be sealed up now.
So I reassembled the top end and put a few miles on it last fall before the dreaded snow hit. After I parked it for the winter I decided to pull the valve covers and back off the rocker gear to relax the valve springs during its hibernation. I noticed that a couple of the intake pushrods were again showing signs of overheating. So I picked up a set of 8 pushrods that are .050” longer in an attempt to keep the tip closer to the oiling hole in the back of the rocker. When the weather turns nicer here in frozen PA, I’ll get some miles on it and check the pushrods again. If they still show signs of overheating, I’ll be pulling the rocker shafts and either have the oiling holes drilled in the correct location or have the rocker bushings grooved to allow more consistent oil flow. It will depend on how far off the current holes are, both laterally and radially.
Also, was able to pick up a spare W2 head from Marketplace that looks to be in decent condition in case of future water leak issues.
Next order of business will be installing the distributor advance springs I picked up from @halifaxhops and tweaking the advance curve so she’s ready to hit the streets running when we finally thaw out around here.
Update
The oil holes in the rocker do not line up with the oil holes in the shaft.
Your pushrods might be a bit short so if your new pushrods still get smoked you need to redrill the shafts so the holes line up.
Do your lifters have the ability to pushrod oil?
If they do, 8 pushrods for the intakes with holes in them would very likely solve your burned pushrod woes.
I did consider that approach but unfortunately it won’t work with my combination for two reasons. 1- my oil galleries are tubed to shut the oil off to the lifters. And 2 - I don’t think my lifters have the ability anyway. Thanks for the suggestion though.
Long overdue update.
I think I finally got the pushrod issue resolved and I will be updating my other thread about that with more info. I’ve been putting street miles on the car and working on the tune up for the past couple months. Finally got to the track last night for the first time with this new engine.
The first pass off the trailer was an absolute **** show. It blew the tires off at the hit and the shifter jammed when I tried to hit second. My hand was so sweaty that it slipped off the handle when I tried to pull second. Like I said, **** show. Ran it out the back at 14.something at 110mph. Embarrassing to say the least.
Checked tire pressure in the Nitto drag radials- holy **** - 30psi! Dropped tire pressure to 20psi and set the Rancho shocks all the way soft. Second pass wasn’t much better. Blew the tires off at the hit but the rest of the run was relatively smooth except that the clutch pedal decided to try and leave its perch. The E-clip that holds the pedal pivot shaft in place had popped off and it started to slide out and **** to the side. I didn’t really notice it until I started slowing down at the end of the track and I pushed the clutch in and it went cockeyed to the floor. Managed a 12.something at 116mph. Going the right direction at least.
Back to the pits. Fixed the clutch pedal issue and dropped tire pressure to 17psi. The first 2 runs I wasn’t leaving on the 2-step, just kind of giving it a couple blips while the lights were coming down. For the 3rd pass I decided to leave on the 2-step and set it to 3400rpm. I do my burn out and roll into the beams. Set the line lock and when the top yellow comes on I mat it and the fuckin thing goes to the 6000 rpm limiter! Never stopped at the 2-step rpm. So I started to back out a little but the lights were coming down so I floored it again and launched. It spun the tires a little less this time but it also drove through the clutch a little bit and I think that actually helped some resulting in the best pass so far. 11.98 @ 116 mph.
If I can get it to make a clean launch and some tuning I think there’s an 11.50 in it.
To be continued….
