273 commando Build
The heads on 1967 273 and 318s are ALL the same,
Closed chamber. I have a 67 formula S and and the heads are closed chamber. 1968 they went to open chambers when they introduced the 318.
Fixed
I coulda swore Uncle Tony said that the SB Mopar was center sump and the combination of that and the windage tray led to starvation of oil...?
I don't recall though I haven't listened to his Gibberish in quite a while...
:rofl: :rofl:
look at this picture .............
I took all the valves out of one of the 920 heads today and just out of curiosity I looked inside the dowel pin hole on the head and noticed the hole is NOT drilled all the way to the bottom of hole the same diameter. there is a 1/8" ledge that is narrower than the pin size.
is there a reason for that? should I leave that alone ? just could be an reason why the head gasket kept blowing not seating all the way down . I believe there is a special drill bit that has a flat shank at the tip .... no pointed not like a regular drill bit .
just trying to address suspicious looking issues on this build.
Wow, thanks for posting that. Do you have the dowel? I would install dowel in block and measure the stick out. If stickout is bigger I would deepen the hole(that's what she said).
Others more experienced will chime in. I'm hoping that's what it is as it seems like an easy fix?
dowels are in the block ... I will measure the hole depth to the ledge in the head and then measure the pin height sticking out of block. also I will lay the head on the block and see how it looks and feels . this is a different engine block now so I have the check the dowel pins
I’d grind the dowel shorter if needed. You stick a drill bit in that hole to go deeper and you’ll wallow the hole out in no time, losing the position accuracy. Dowel holes are reamed after drilling undersize.
ok I see ! the smaller diameter is the pilot hole for the actual larger pin size.
update
got one head ported except for around the seat and guide..
not sure what shape around the guide boss I should have . what do you guys think ? I have watched tons of videos and everyone has a different opinion how to shape that area.
update on porting :
finished one head ...
it's not a full port job, but overall it does appear to be much better than stock.. it is opened up some and cleaned up. all rough extrusions removed. very happy with results !
just mocking things up on the 273 . laying head gasket on.
here is what a oem 318 composite gasket roughly 3.9__ to 4.00 bore fire ring looks like on a 273 head.
also I finished the other head port and polished ..
See the Mopar head gasket package in the back ground - is that the set your using ? That's looks like what I have - they aren't metal but came in a USAF sealed outer package.
Yes, those are oem 318 head gaskets I will use .. and they are composite. they came to me in a nice package . double wrapped .
That was what I was going to let you know about - but was afraid of the "composite" since you were having the issues.....best of luck with the build looks like your on your way !
Progress !
finished up with the 920 port polish project. just need to assemble hardware yet. I think I did a great job on the head porting and I will see definitely more hp and torque for sure...after port and polish I degreased along with a soapy bath and blow dry and then oiled all bare casting areas. and last a paint job..... the task was a tedious one for sure and you just have to stay focused .. and keep an eye on which direction the flow is on either valves.. assembly is next in line.
OK... the other head is all assembled . this 273 is going to ROCK !
now I have to wait until in warms up here in Wisconsin to finish installing the heads and intake and install engine into my 65 barracuda formula S .
