Pretty awesome heads for a standard rocker.Hard to believe TF240’s have been out for nearly 10 years already.
The first one I tested here was in 10/15.
They have certainly made a big impact on that market.
I ended up having a pretty wide back cut, wider than I wanted but that's just how they ground out.Impressive gains in the lower part of the lift range!!! And also pretty dang good up top on the intake flow. Nice work! Regardless of percent difference for the benches, you’re still able to see the magnitude of the modifications, and that they took you in the right direction!
Lol, yes I agree 100% just buy the 270.I believe the best flowing std port/non-offset rocker BB head I’ve tested were pretty nicely ported Indy SR’s.
Nothing extraordinary done to them, but those heads are fairly labor intensive to port to get good numbers from.
I’ve never done any rework to a TF240, so I don’t have first hand experience as to how they respond.
TF made the decision pretty easy for how to step up the 240 head……… just buy the 270.
I’m def looking forward too your restest on the dyno!!
Thanks RJKeep it up Korie good work.
Thanks for the experienced insight.Nice work, it may seem like a never-ending battle but just keep doing something every day. You'll get to a point when reason sets-in and know when things are good enough.
I have thought about doing that in some fashion. That should hold. How deep did you go into the bulkhead? Obviously it tightens-up the register function. There just isn't a lot of material to work with. Did you ever flow the 240 TF head (b4 and after)? Keep moving. In the meantime, nice work!I have been working 7 days a week this summer to try and keep up with bills since my wife still isn't working, she has an interview on Thursday so I'm excited.
Im sort of back at it with the car, I have my heads back at work to set them up after a final clean up surface and port match the tunnel ram/ fix the angle on the intake flange.
I have done a couple things on my block, I added a .062 hole on the rear of the thrust bearing and drilled my block and caps so I can stake the 2, 3, 4 main caps.
That added a ton of stability to the caps. It took 30 minutes to remove those caps because they wouldn't budge even with the studs out.
I still have to fill the cooling passages, hone the cylinders and have it line honed again.
I'll be getting back to it more after my wife gets some income.View attachment 1716447294
Thanks Sean, I drilled 1 inch into the bulk head 7/32 drill bit, had to step up 1 size from what I originally thought would work but the 7/32 has plenty of press.I have thought about doing that in some fashion. That should hold. How deep did you go into the bulkhead? Obviously it tightens-up the register function. There just isn't a lot of material to work with. Did you ever flow the 240 TF head (b4 and after)? Keep moving. In the meantime, nice work!
489 cidThe Trick Flow heads can make power, a local racer had a low deck +030 383 with a 4.25 stroke crank, not sure of the displacement but it’s less than 500”. He had just bought the 240 heads when the 270s came out but he stuck with them and his low deck made over 750hp , how much more he could have made with the 270s but you need to think about that stock block you have and do you really want to blow it apart making more power.
This 470 has made in the 680s with a pretty small solid flat tappet, incorrectly ported tunnel ram.The Trick Flow heads can make power, a local racer had a low deck +030 383 with a 4.25 stroke crank, not sure of the displacement but it’s less than 500”. He had just bought the 240 heads when the 270s came out but he stuck with them and his low deck made over 750hp , how much more he could have made with the 270s I don’t know. But you need to think about that stock block you have and do you really want to blow it apart making more power.
Looks cool; you gonna throw it on the flow bench to see results?Just took lunch and redid something on my intake valves.
When I originally did the valve job I added a back cut ...well let's just say I didn't know any better,
So I chucked the valves into the surfacer and ran a 15° out to a much narrowed and steeper 38°
back cut.
It left a step I needed to remove, bad enough I was considering buying a new set of valves.
Anyways with the "f" it mentality I came up with this semi rough swirl and blended my mess up to the stem and just about made everything the same with a cut off wheel and the valves chucked in the drill press.
Sorta happy about the results.View attachment 1716447722View attachment 1716447723
Probably not, that's 3 hrs away.Looks cool; you gonna throw it on the flow bench to see results?
Thanks RJ, I appreciate that a lot.I love the willingness to experiment and do all this stuff yourself Korie. Lots of respect for this project.
Look on Summit, they have sheets of gasket material in different thicknesses. Here’s 094:I fixed the flange angles, I thought I messed it up while I was surfacing it. Long story I don't want to type it out lol. Heads are resurfaced .007 off the heads and .016 from the bottom of the flange .000 removed at the top to get the angle correct.
Floors of the ports line up great. I need to somehow make a .090 gasket to duplicate the perfect fit and port match the intake roof to the heads, then try to make the intake look decent.View attachment 1716449286View attachment 1716449291View attachment 1716449293View attachment 1716449295
I appreciate that, thank you. I wasn't successful myself finding that thickness.Look on Summit, they have sheets of gasket material in different thicknesses. Here’s 094:
Gasket Material, Sheets - 0.094 Gasket Sheet Thickness (in.) - In Stock Filter Options - Vendor In Stock Filter Options - Free Shipping on Orders Over $109 at Summit Racing
Having made my own exhaust gaskets, make a few sets. Your first one or two will be okay, the next few will be better. Then you’ll have spares for when you need em quick for tearing into something and don’t have to spend time making them in the middle of a thrash.I appreciate that, thank you. I wasn't successful myself finding that thickness.
Thank you very much.
Awesome.Having made my own exhaust gaskets, make a few sets. Your first one or two will be okay, the next few will be better. Then you’ll have spares for when you need em quick for tearing into something and don’t have to spend time making them in the middle of a thrash.
