sidewall pinhole repair?
pishta
I know I'm right....
Tustin, CA
Kenda 16" tire on my minivan. Thing still has the nubs on the side and ~90% tread, probably less than 5000 miles on it but Im not the original purchaser, on vehicle when I bought it used. Its obviously a defect in the sidewall as there is no indication of any abrasion there or puncture. We pulled the tire off the rim and looked inside and there was a small inclusion inside where the pinhole is. There is a very slight ripple in the sidewall where this pinhole is (just barely feel it running hand over it) like maybe a cord broke? The spot is almost exactly centered between tread and bead. Wondering if I can patch it from the inside to use as a full size spare on a steel rim as the stock donut on this vehicle is a joke. When running the 60 psi donut on the rear at about 40 mph it feels like the SOB is flat or the rim is bent? I pulled it over to check of the lugs were tight! Neither is the case...do these temp spares ever get balanced? I know your not supposed to plug a sidewall as they flex but Ive heard folks running slime in a poked sidewall for years with no issues.
was thinking a 2" circle patch out of a kit with supplied vulcanizing rubber cement?
Just go to a junkyard and get another wheel with a tire. A used junkyard tire on a steel rim is like $30 here. It's $60 for aluminum because they charge you a core charge here.
A junkyard tire is a lot easier than messing with a sidewall
It's also cheaper than real sidewall repair kits for offroad tires
Sidewalk repairs never work, too much flexing of the sidewall. Maybe talk to the OP for his paperwork? Obviously a defect in construction.
That tire is smoked. If it's from a defect even more so than if it was a puncture. Getting it to hold air is the least of your worries, the price of a new tire is nothing compared to what could happen if that thing comes apart.
I agree. I would take a pic and send to the factory if you don't have any other recourse as for a warranty. You've got nothing to lose and since it isn't a punture from the exterior youmay have a good shot at getting one.
Im gonna say, heck no. Dont play with safety issues. I thought the reason they wont patch sidewalls ( or even near sidewalls) is because the movement will generate heat or a failed repair. Either way....you cant live with yourself if you hurt a loved one trying to get away cheap for no good reason.
If it's in better shape than the spare you currently have, go for it.
Not sure if the spares ever get balanced, but it wouldn't take much to do it anyway.
Most places offer road hazard insurance on new tire purchases. That would be considered road hazard if you have that type of insurance.
Can't put a tube in it?
van has TPM so it would always register 0 and a warning. thought about that. And since I'm not the original purchaser, i'm assed out of any warranty claim. I may still keep as a full sized tubed spare on a steel riim for long hauls as the donut is useless until I figure out WTF is wrong with it. Remember when all spares were full size and then even an option? My work truck doesnt even have a spare, the garage pulls them so were forced to call fleet if we get a flat. I guess our insurance doesnt cover me changing a tire? (but Im responsible for everything else on that vehicle maintenance wise...) The tire community is a broad spectrum: on one hand concerned folks will tell you "no chance, change it out" and even scrap tires that are out of date (that gets pricey on a weekend cruiser), while the other side remembers growing up with POS cars with 4 different tires and having blow outs that just woke you up and made you calmly pull off the road and change it in about 10 minutes with a semi flat spare you had cooking in your trunk for 10 years.
Never attempt a s/w repair on a passenger tire.
The true cause of failure often requires the tire to be dismounted and inspected from the inside.
Not a defect for sure.
A damaged tire.A pin hole is much different than a broken cord.
A pin hole can be repaired with a special glue for the liner which is the actual air bladder/tube portion of the tire.
Made of impermeable rubber to hold air. the cord holds the load.
Broken s/w cord= junk tire.
Low profile( short sidewall) tires are very prone ot impact breaks. Just run over any thing like a pot hole, train tracks etc.. at too high of a speed or too low of an air pressure and the s/w will get pinched for a miilesecond between the rim and tire.
Urethane Black Windshield Sealant
24 hour air dry cure time.
Spendy...
Don't get any on your hands, about impossible to get off.
