i agree whole heartedly. if you're starting from zero or your stuff needs work *something* aftermarket makes the most sense economy wise.It's a little disingenuous to say "65 hp for $1500" because you would have had to spend money on the iron heads to make them fresh enough to use, THEN add up your time porting them. So the actual cost difference in the real world is almost zero.
question: are the AFR's good enough to run OOTB? or do they need a once thru? and if they do what's the coin for that?
