Too much intake? RPM Air Gap on a stocker 360
I have an RPM air gap on a 9:1 360 in a 1979 truck with 600 AVS2 carb, electric choke. Don’t remember the cam specs without looking it up, but it’s a smallish Lunati HFT. East TN, so winters aren’t terrible, but we get cold weather. No cold start or cold run issues whatsoever. I have been very pleased with the air gap and AVS2 combo.
Truck cam would look like to me..
Around .458/.479 204/214 112.. like the old hughes/engle grinds. Used one in 318 ram charger...worked great.
Also done a fitech on rpm ag with .500 hyd roller/ 250's cfm iron heads, at , shorty headers... works great.
I had a stock bottom end 360, comp XE262, headers, a little bowl porting on the stock 1.88" heads, RPM air gap, and a 600CFM edelbrock carb and that combo pushed around a 4000 lb chrysler 5th avenue with an A500, about an 1800 RPM converter and 3.55's very, very well.....performance was comparable to a first gen 300C AWD with a 5.7
What the end goal? A truck for work and towing or a mud toy or jacked up strip club parking lot queen?
I like the question on transmission, gearing etc. The combo need to match.
I run a Sniper on a Stealth intake with no issues, but I used an open gasket.
Look at the Eddy Air Gap RPM range 1500-6500. That's pretty much where you'll be anyway. Bolt it on.
oh man... there are so many species in that genus!
pavement princess, bro-dozer, burger cruiser, mall crawler, hump trucks.
lots of applications, totally different needs for each!
Its a work truck. General kind of keep her running, but now she is blowing smoke. So i yarded out a ‘75 360 i had and he is giving it a go.
It’s a good looking truck. Faded but straight.
Ill get gear/trans info today (maybe even a pic of the truck for all your guyzes well thought out input)….. but it sounds like a “send it” situation.
600 vacuum secondary carb and good to go.
It has a factory tbi in it and since i had a tbi hanging around…..well we thought why not? But…..we haven’t checked if the factory fuel pump puts out the 58 psi needed to run the Holley. I kind of doubt it. I hesitate going through the effort of getting the box/coil/dist to marry to the sniper unit when there is some uncertainty of other parts playing nice.
I am currently running a 1st gen sniper in my big block barracuda with success, but following @AndyF advice i got all the supporting parts (box/dist/coil) to communicate together.
I'm pretty confident the TBI only needs 34 PSI to run and the later magnum "kegger and rail" intakes needed 58 PSI to run. But I don't think it's going to be optimal deleting the EGR. The factory TBI 360 intake is not a bad piece, and if you're going to run TBI, I would advise staying with it. Those also have a large coolant loop in the bottom of the intake and I'm fairly certain the TBI setup needs the extra intake heat for proper operation. It's not going to perform anywhere near as good as a carburetor with a proper distributor curve, but it's definitely good enough if you're wanting back and running in a hurry. Also, bear in mind that if deleting the factory computer, you'll have to put a conventional voltage regulator on the alternator or go with an internally regulated one wire alternator and external charging loop. The charging is handled by the TBI computer, and if it's setup so that if the check engine light bulb is pulled, it bricks the charging system. Needless to say, they don't take well to anything else being disconnected either! If he chooses the air gap route, an out of the box 650 AVS2 is very near absolute perfection for it. I promise recurving the '75 distributor and going with a carburetor and the air gap is absolutely worth it. IF that's a hydraulic roller cam LA 360 out of that truck (usually heavy duty, ram charger, and 3/4 or full ton van) and he or you don't want to hold onto it, post it up here to sale... Those engines make a great starting point for almost any 360 build, someone would be glad to get it!
Slight derail, but since we’re talking trucks and all, here’s a cherry pick from the best parts out of the pile at my cohort’s place. It’s getting the pictured 68,000 mile 360 hydraulic roller setup with an NP435. All very low mileage (think of trucks lost way back in impound yards) with near NOS and some actual NOS parts. Still deciding on axles and tires, but it’s got four inches of lift. The doors open and close like new.
i run the non air gap rpm on a stock *** 360. runs great..
My knowledge is challenged to differences of non air gap to regular air gap intakes. I’m assuming one is taller?
This is the first small block i have been involved with.
The issues brought up before about the EGR and the stock computer that runs the stock tbi are tough for my monkey brain to tackle all at once, while trying to make quality decisions. It’s all simple if you have done the job once…. Or so i believe.
So, plan is to remove smoking 360.
Put the small cammed rebuilt motor in with the air gap on it (because that’s what is lying around) and see if we can get it running with a 650 Holley that we have. Trouble shoot it. Pray. Cry. Repeat.
I’ll update with info as i receive it.
Options also include…. Just put the stock intake/tbi back on.
This is a 89
Daing! That’s a REALLY nice 3/4 ton truck right there. Are the wheels aftermarket or factory on that? It’s got a Dana 60 with 3.54 or 4.10 gears in it. There may be sticker on the reinforcement rail of the hood on the front drivers side showing the gears. I love the charcoal and silver combination on those trucks, though. They would definitely be a 360 hydraulic roller. Oh the things it would do in there with a four inch crank and some extensive headwork from MOPAROFFICIAL…
Transmission will either be an NP435 four speed (which usually came equipped with 3.54 gears) or a 518 overdrive automatic with 4.10 gears. That one has given me some seriously bad “truck envy” right now, even though I really don’t need that type of truck at the moment.
