Amp Meter connections
Wire is not cut all the way through Dell. Looks like somebody was trying to test it at some point
That is for certain going to have to be cut at the damage and either connected to the black as mentioned, or repaired/ extended with a new eye.
Agree that is the seat belt buzzer connector.
If you want a new ammeter, do a search for mopar 3592196.
Used and new ammeters can also be found on eBay.
WHAT is that bare cut red wire?
Need a better photo of the question connector, what is it's layout and wire colors
DO YOU HAVE a 74 manual. If not I can MAIL you one but that is the only way, as it's too large to up/ download. Send me a PM/ "conversation."
In the back of the manual past the wiring diagrams are layouts of the connectors, if they are OEM and not added, of course.
Is this the connector?
Yes Dell, I have the 74 Manuel, and I'm pretty sure that the connector. Thank you.
You guys think this is why the car only starts occasionally and was surging? thoughts
How should I joint the two ring connectors? I would rather connect them with a butt connector, but I'm going with a factory ammeter connection later
It does and I think that’s a result of the loose, burnt connection. Not a cause.
I remove Vixen's cluster and check those connections every other oil change. I also remove and inspect the firewall connectors.
Starter issue sounds like either a starter relay, or a neutral safety switch.
Make sure that you're doing ALL of this work with the battery disconnected. Dropping that ammeter wire onto any frame or chassis part that's grounded is a fire waiting to happen.
Insulate the hell out of those ammeter wires, after you bypass the bulkhead connector with them.
How about one of these?
If you are going to insist on keeping the ammeter, I would research and learn how the so called fleet/ police/ taxi wiring was done. This was a "partial" bulkhead bypass. And, you'll want to be certain the ammeter is in tip top shape, AKA replacing the studs and so on
You are talking to a guy, who LIKES ammeters, but even on my 67, I converted it to an voltmeter
Just use a short bolt and a nylock nut. Then make sure to cover it with either tape or shrink tube.
Looks like that wire was hot and shorted on the sharp edge below it. I changed my mind about bolting them together. Cut the red ring terminal off behind the short, and solder or crimp a new ring on, then bolt them together.
I would only go so far as to say it could have been a contributor to electrical issues.
Hard to say where it started until the ammeter itself is removed but the heat damage seems to be at the wire going into the terminal. However I have theory that someone messed around behind the dash and moved the wires.
The wire routing here looks like someone had been in there and moved the harness and or connectors.
I think the insulation got worn where it was touching the headlight switch. Eventually this may have caused some occassionally grounding although the copper conductors aren't showing burning in this photo.
The ring terminal on the Red (A1) wire looks to have more corrosion and heat damage than the ring terminal Black (R6A) wire. Again leaves us wondering if that stud got yanked, or there was more water (leak) that landed on it, or the wear on the insulation and conductor led to resistance and heating during recharge.
AFAIK the ammeter wires on models with this instrument panel should be coming along the top of the dash and then over the headlight switch, as shown in this '70 Plymouth Chassis Manual.
Do a search here on splices
Heres a couple
But the ring terminal and the lead going into it at minimum needs to be cleaned up.
And all of the other connections still need to be checked.
You're right Mattax. Somebody was in there, and they had three different types of screws holding the Cluster in. Interesting on the way the wires were routed. I have to check closer with all the wiring. I'll post more Pic's
I agree. If the conductor is damaged then bolting them together doesn't solve that probem.
Can't tell from the photos whether the ring terminal and the wire lead can be cleaned up and then spliced in. Should keep that option open if a new ammeter is in the future.
Regardless I would not just bypass the ammeter and assume that and the damaged feed wire are the only issues.
I agree. It’s likely the shorted wire and burned up contacts on the ammeter affected stuff down stream. Fix that, then continue to diagnose the rest of the system.
Clipped off the red Terminal, and you guys were right. It looks like the end overheated at some point. Here is a Pic- not looking too good. I was going to splice it in, but it's a little rough. Looks like I don't have a ring terminal that's the right size. I see what you meant by keeping it Mattax
Terrible. Should be obvious. Corrosion can migrate up inside the wire. At the very least cut them off to fresh wire and properly crimp new terminals on. There is no real need to seal them as the factory did. None of the rest of the connector terminals are sealed, AKA the headlight switch, or the ignition switch connector, nor are the bulkhead connectors sealed except minimally around the connector body.
This is from a Jeep but is an example of corrosion at the break in the insulation, and some oxidation (dark) on the conductors under the insulation. If the blue green is under there or its really oxidized, keep cutting back until i stops.
If you're skilled maybe you can save it. Those 12 gage terminations are hard to crimp. You maybe able to reuse the insulation. I haven't experimented enough to say what adhesive will stick to it. Alternative is to heat shrink several layers and/or liquid tape (messy). One thing the insulator there does is reduce the chance of accidental shorts.
Del think back. Almost all of the terminals on the main wires are sealed like that. Even the ring terminal at the alternator got sealed at some point (not all years). I think the downside is that when they do get hot, there is no air circulation to let it cool quickly.
For example
Ok experts, what connector would you use to connect the red amp meter to the black one. I have Heat Shrink to go over everything. Black Amp Meter wire is in good condition.
I think you’re over thinking it. But I’ll add this, any time I use a solderless crimp connector, I pull the plastic insulator off, crimp it lightly, solder it and cover it in heat shrink. Works a charm.
