Turbo440Dart
crank runner over-er
The numbers are posted above. But here’s one I took a pic of
I talked to him before he even asked what it made so he knows. I believe we have discussed his turbo duster a time or two.
No one talks about or cares about Beak Nose DustersI talked to him before he even asked what it made so he knows. I believe we have discussed his turbo duster a time or two.
If it has a spinny muffler on it we do.No one talks about or cares about Beak Nose Dusters
On what I consider to be safe timing numbers. We pulled a bunch out of it compared to what it was running on the old combo.880wtq![]()
That’s a question for Chris. I was there for moral support. And I may have twisted a screw or two. The goal (if I can speak for Chris somewhat) was to have a safe tune up in the car and make sure it wasn’t going to hurt itself. The power is a bonus. We knew what potential was there, I mean it’s a big block with an 80mm snail on e85, anyone should know it’s gonna sneeze big power. Now it’s all about controlling it and using what you can.Just curious, based on the traction you will be able to get, do you have a goal for power? or just ALL the power?
That’s what everyone says in the beginning. I’ve never seen anyone, not one person (myself included) stay there.I just want a nice comfy 5psi.... nothing too big![]()
Go do it. Please prove me wrong. Put 5psi on anything, I’ll bet you $1000 it won’t stay there for more than a year. There are a lot of guys here with boost on stuff, we should start a poll.See... i'm soo cheap though that anything over 5psi would have me too worried bout blowing stuff upKeep it safe and cheap!
Thank you for once again proving that a big block can survive big power.
With that kind of power, you've got to be bumping up against a thousand at the crank, right?
Man that is Impressive!Id call it high 800, maybe 900 at the crank on 14. Which is terrifying considering it’s a stock crank, stock caps, stock cap bolts and no girdle in it.
Meh, we shoulda turned it up for a big big numberId call it high 800, maybe 900 at the crank on 14. Which is terrifying considering it’s a stock crank, stock caps, stock cap bolts and no girdle in it.
hey man, when i get out there to play figure it to be a 50/100 dayIt was a 40/60 day. 40% of me wanted to but 60% of me didn’t want to push a mop
