9secRR
1.23.What is your 60'? It sounds like you are setting into the chip on that 2-3 shift.
the shifter got stuck from 2nd-3rd. i have air shift and the air kept the shifter stuck between 2nd and 3rd. i tried to pull the handle but failed which resulted a few bumps on the rev limiter. i actually had to look down at the shifter to see what the problem was.
