Hitting tire to hard? Video added
What is your 60'? It sounds like you are setting into the chip on that 2-3 shift.
1.23.
the shifter got stuck from 2nd-3rd. i have air shift and the air kept the shifter stuck between 2nd and 3rd. i tried to pull the handle but failed which resulted a few bumps on the rev limiter. i actually had to look down at the shifter to see what the problem was.
1.23.
I would imagine temperature and track conditions have a lot to do with bite. Could you bump the pressure up a half pound per pass and see if the 60' starts falling off?
I went from 8.5 -9 psi and it didn’t change. I wanted to try 9.5 but then this happened and ended the season. Bent the ladder bar bracket.
Was looking at buying some serious carbon fiber tube in 3” to make an anti roll bar out of.
