302 heads-Is it worth putting them on a stock 318
I never even looked at the date of the thread! I just noticed 302 and said to self, that's what I have! The original heads on my donor engine were cracked between some of the valve seats and Hughes was adamant that with the combo I was considering prepped 302's would be fine.
A set of ported of 302 heads is fine for the power your looking for, but there’s way better heads to swap to, there a bunch of people that push these heads for whatever reason. But you got them and wouldn’t sweat it, you’ll make decent power.
I
Here we go. I would bypass the 5.9 Magnum swap and go right for the Hellcat or Demon Gen 3 Hemi swap. Geez!
His post was swap 302 heads on stock smog 318 or wait to swap in 5.9. If those are the two choices then I'll go with the 5.9. 5.2 magnum would be a good low buck swap as well. Not hating on 318s in any way.
Right, lets just skip all the non-sub 10second garbage, & go right to the Flux Capacitor....stop Fooking around already!!
Right to the Future!!!, oh, We did....& here we are again....
Yep, here we are.
Depends on what year your Stock 318 is?
'68 & '69 are the stock 230 hp 9.2:1 compression engines.
Same with the '89 - '91 318 roller engines 9.2:1 cr and these come from the factory with the 302 closed chamber heads.
Both of these engine years perform well and run very nice with the stock cams and the Edelbrock 1406 4 barrel upgrade. Even the '68 & '69 318s running the stock open chamber heads perform nicely. Gives them the fuel that they need for that "Extra" kick.
All stock ^^^ '69 318 with added 1406 Edelbrock 4 bbl.
Would I do it again?
In a heartbeat.
The real trick is to ditch the stock 2 barrel economy carb, and upgrade to the 4 barrel. Night and day difference.
As a side note: a fresh set of heads with the new valve job is always a good thing. As with high mileage used engines, the valves are the first thing to start loosing compression .
I have a little 318 that is totally stock and I have an opportunity to purchase a set of 302 swirl port heads for a reasonable price. Is it worth installing them on a totally stock 318 for a slight compression bump and flow? Currently it has a set of late 70's heads.
Cam
Then you will need a torque converter
Then you will want different gears
Then you will want to replace the 302 heads with some aluminum heads
Now you will 'need' a new intake and carb(s)
Then you will want to stroke it
Then you will need a newer cam
Then you will want a big block. I suggest the 383. ;)
Don't start down the carparts highway to hell!
I’ll throw my .02 in here…….
For mild to mild-ish 273/318 combos where the desired power output is roughly in the 1hp/ci or less range, 302 heads are basically as suitable as other 318 heads.
If you’re looking for more power than that, there are easier paths to get there than using small heads on a small engine.
A couple of posts ago it was talked about "68-9" and "89-91" 318s and their CR. Actually they advertised 9:1 from 85-91.
But I have to ask, how "true to form" are those numbers? I've cc'd a couple of different engines plus reading of others doing the same on a rebuild, and stock, unmodified they usually come out short of what's advertised in the manuals.
Between the pistons not being as close to TDC as they could be (or are advertised as being), and combustion chamber volumes actually being bigger than advertised, unless you blueprint it and machine parts as needed, you probably aren't getting what you think you are.
Dont have a flow bench. But on a 318 you dont want to hog them out or you decrease port velocity and hurt performance. Just transition them from a big port intake so theres no ridge and the air flows smoothly. I am using a Weiand Stealth #8022 which is pretty much an Edelbrock LD340 copy.
I'm sure if you stick these on a 340 or 360, you could go with bigger valves in these and do some serious port, runner, and bowl work.
What you want to do with the 302 head is fix that fuggin chamber that shrouds the valves. Those heads, as cast, flow terrible. You'd make more power fixing that chamber and doing a good valve job on it then you would opening the port windows up like this and not fixing the chamber.
I have plenty of videos on my YouTube channel covering this.
The piston only has a finite amount of surface area to pull an Air Fuel mixture in. Piston diameter being 3.910" as opposed to a 340 which is 4.040" I think. Now on a 340 you would want to hog them out a bit since the piston has a larger piston surface area and will benefit more from this.
Port matched 302 heads to LD4B 318 intake, gasket matched too, just like above.
Stock 302 Heads, no alterations. Stock built '69 318 9.2:1 cr engine. 340 cam of course.
2 1/2" TTI Exhaust on Port Matched stock exhaust manifolds.
Drive with 2 hands !
