Hell ONE FULL QUART won't overfill one. People don't get that. Imagine it spread out over the whole area of the oil pan.If you need the 3-4 ounces of quick return oil, put a smidge more in it. The extra oil will carry heat off too.![]()
Thank you, I appreciate the complimentThat silver really looks sweet!
Yeah, how much more slippery can it get? Like the most popular girl on prom night.The way I look at it, when the engine is running its oil on oil so it doesn't matter I think.
LolYeah, how much more slippery can it get? Like the most popular girl on prom night.
Don't you really mean "imagine oil spread out all over the inside of every running motor?Hell ONE FULL QUART won't overfill one. People don't get that. Imagine it spread out over the whole area of the oil pan.
What do you call "COLD" oil temps? LMAODon't you really mean "imagine oil spread out all over the inside of every running motor?
The higher the RPM the more oil gets sprayed into every nook and cranny in the motor, valve covers, timing cover, bottom of the intake valley ( AKA thecam and lifter valley) cover. The colder the oil temps the slower it runs back downhill![]()
Any oil temps below 140 FWhat do you call "COLD" oil temps? LMAO
Ummm yeah it'll be above that shortly after startup. Moot point.Any oil temps below 140 F
Straight 30Wt is worse, I have switch to VR1 10x30Wt oil in my race motors now and either 0w20 Wt. or 5W20Wt in my daily street drivers depending on the time of the year I am changing it forI tried draining 20-50 out of my oil pan on a 70° day and it barely came out
Yes. But they're out of business now.Can you point to a mass engine builder like say Blueprint that uses it?
Excellent questions. I'll say that if I had been given a choice, I would have traded the glyptol for time spent removing all that flashing. That might have improved oil return.I haven't seen the inside of a current cup engine for a while. Wonder if they go through this. Those guys don't waste time and effort on stuff that isn't effective or beneficial. F1, indy car?
I remember RHS. Racing Head Service. I always thought it sounded like a speed ******* company.Yes. But they're out of business now.
This was built by RHS (sister company to Comp Cams) around 1988. I head the heads redone around 1990. Here's how it looked when I sold the block around 2013.
I'd say it held up pretty well.
However...
It does look nice. I had to look at it multiple times before I finally decided it was iron. lolThank you, I appreciate the compliment
LolIt does look nice. I had to look at it multiple times before I finally decided it was iron. lol
Wishful thinkingI remember RHS. Racing Head Service. I always thought it sounded like a speed ******* company.
Of course, you think that wayI remember RHS. Racing Head Service. I always thought it sounded like a speed ******* company.
Did you have them do any work on some of your parts or are you repeating criticism you heard from somewhere else?Who criticized? I made a joke. Lighten up Francis.Of course, you think that wayDid you have them do any work on some of your parts or are you repeating criticism you heard from somewhere else?
Have you ever measured how long it takes the engine oil to warm up under different outside air temps and different throttle openings? How long is "shortly"?Ummm yeah it'll be above that shortly after startup. Moot point.
Shortly. Like your manhood.Have you ever measured how long it takes the engine oil to warm up under different outside air temps and different throttle openings? How long is "shortly"?
And you know how long it is by?Shortly. Like your manhood.
Touche, essay![]()
reminds me of a joke:What a shitshow...
Essay is something you write in school for a grade, Ese
Your "La Eme" membership card is on the way.
