PikaPhantom
Temp broke as I was installing it. Wondering how I would go about trying to get this off
From where would you recommend chiseling from?Its brass/soft. Easy out might grab it or might just chew/ream it. I would just drive a keen chisel through behind it. It'll split and curl up, and fall out. I've ground a few punches just for this kind of use. With care, damage to the cast iron threads is minimal.
Drill it out, heat the brass with a torch let it melt out.
Run a tap thru the hole, easy fix.
