TheCraigMachine
Searched for an answer to this for quite a while, haven't been able to find any hard facts on this topic.
A quick rundown of the combo im working with here:
Rebuilt low compression 318 shortblock
.030 over pistons sitting .105 below deck
Fully ported 302 heads running 1.78/1.60 valves, with a .050 cut on the deck
Summit SUM-6901 cam
Weiand Stealth intake
600 Edelbrock carb
Magnum exhaust manifolds, 2 into 1 exhaust, 3" pipe to rear.
Calculated static comp ratio of 8.6:1
Lightweight early valiant.
*Not yet assembled*
I had originally kept the 1.78" intake valves based on the advice of the now discredited BJR, but im not happy with the way the valves are sunk deep into the seats after the 3 angle valvejob i had done. The exhaust valves sit nice and high in the chamber, but the intakes are way down low.
I had these heads running on another factory shortblock with this combo already, and the car ran really strong and would rev to the moon. So much so that I blew the old shortblock in very short order.
My question is: while ive got this thing apart again, does anyone think that it would be worth the ~$200 to have the heads fitted with 1.88 intake valves? Would I ever even notice the difference from before? If it would only be worth another 10 or so HP, the cost would outweigh the gain. Plus, im worried that the closed chambers of the 302's would shroud the valve too much.
If anyone here has any experience with this, please let me know! Thanks.
Summit SUM-6901 cam
600 Edelbrock carb
*Not yet assembled*
