mario03srt
Here is my home brew CAI fed by the Mopar Snorkle. Thanks to FABO.10.2:1 is borderline for detonation on pump fuel. You may get way with it with some careful planning. Heat is the problem with det. If you can reduce engine heat & use cold air induction, that will help. So a good free flowing coolant system. Blocking off some of the exh xover heat will probably help to keep the A/F mixture cooler. A friend had an engine that pinged & he installed an engine oil cooler. No other changes, it stopped the pinging.
