2/9/25:
Some progress has been made.
Last Week, I was able to do some cutting, grinding and welding on my semi-custom valve cover. Still quite a bit of work there to get things all done.
Gasket all coppered up ready for an install:
Lifters installed:
Head installed and Torqued to Spec:
The last time I had the engine together I was unhappy with the oil flow to the rockers and top of the engine.
The only thing I changed on the last iteration in 2023 was the head bolts(studs).
On the other performance engines with the ARP Head studs I have built ('69 Dart)
and (the Ruster)
I always turned or had a machine shop turn for me one of the studs down to the diameter of the stock head bolt so that the oil passage to the rockers would not be restricted around the ARP Stud, which is noticeably girthierer than a stock head bolt.
I did not do that last time but I did this time, so hopefully I will be happier with the results.
So except for the the Intake, Headers, some hoses and other bolt ons, the engine is complete, I set the Timing and Cold lash so that after priming the oil pump with no spark plugs and compression, I should be able to Put fuel to the carb and Fire it right up.
One other thing that I did was begin to find out where and how much of the # 6 header tube I need to cut to use the Weber DCOE style EFI setup. I need to completely cut and then add some radiused length of tubing for the # 6 tube for my manifolds to work together as the intake also hits the #5 intake runner as I have removed half the diameter of the #6 tube already. No amount of just dinging it would work here, I would have closed up half of the tube or more.
