1965 Barracuda Hub Needed
ivy1960
New Member
Newport Beach, CA
On my front right wheel one of my 5 lugs (SBP) has stripped at the hub on my drum brake so now it is free spinning. Does anyone have one for sale or know where to find a replacement. I would prefer not to have to weld it on. Any help would be greatly appreciated!
Do you just need to replace the studs and lug nuts or the whole thing. Replacing the studs isn't that difficult. I have a friend who replaced all of his just so he wouldn't have left and right hand treaded lug nuts
I vaguely remember there being repair studs w/ larger spline diameter to fix this, but your 7/16" thread might make it tough. Most people weld to repair them. The front drums are cheap new ($22 rockauto).
Just remember if you change drum on the hub, to cut the swedging on the stud, first. If you try to drive the studs out, you will probably ruin the hub.
Been offline with the flew. I do have used 10 inch hubs, with and without drums
