The Transmission for this car is in PA. Will pick it up at the Carlisle Mopar show in July...I hope...not really...68 should be easier
NOT early. Will not go in unless you dropped the cross member 2 inches... Not practical IMO...And the pinion angle would be honked up, not to mention the fan getting close to the radiator...not really...
two basic ways to go on and A, mod the crossmember and lower the whole thing so you only need to beat on the floor, or cut the floor and hang it on the stock mount. the lower you hang the trans, the more work you'll probably need to redo the exhaust.
2 1/2" TTi crossover / GV heater before eliminating it
you'll love it once you get it done
This is the reason I stuck with 904 and GV unit, No other swap will allow you to use factory mounts and location for console....
I was, but was assured it was engineered to work and was behind thousands of engines. So.........who knows...Real nice, Tim. I do have a question though. Aren't you a "little" concerned about all that weight hangin off "back there" behind the factory cross member? It just seems like a lot of length with no support.
Well, got it all in, and running. BUT still have to figure out why it will not shift. Have not trouble shot it yet......
The GV unit.....The GV is not shifting or the transmission?
