1970 Duster factory chassis paint details.
Chris 340
Denison Texas
I'm a brand new member. I just picked up a 1970 Duster with a 340. I would love if someone could help me. I want to paint the underside and suspension and wheel wells as close to factory as possible. I have tried to find a restoration manual but I have had no luck. Are they all body color? Thanks again for any advice. This car is not a show car, I just want the things that need attention to be right.
This may help you. I've relied on it for years here in my powder coating shop.
Mopar Chassis Color Chart
Legend:
BC: Body Color
GB: Gloss Black
SB: Semi-gloss Black
CI: Cast Iron Gray
N: Natural Steel or Aluminum
MP: Manganese Phosphate
CC: Color Code
(*): Some Mopar core supports are body color with semi-gloss black sprayed
on the grill side. There are some variables from what is shown above.
Assembly:
Front Unibody subframe assembly BC
Inner Fenders BC
Firewall BC
Core Support BC*
Transmission Components:
Transmission N/CC
Driveshaft N/CC
Transmission and driveshaft Yoke N/CC
Differential Housing SB
Clutch Linkage N
Brake Components:
Brake Drums SB/N
Disk Brake Shields N
Calipers CI
Master Cylinder GB or CI
Axle/Suspension Components:
Axles N/CC
Third Member SB
Upper Control Arm GB
Lower control Arm GB
Inner and Outer Tie Rods N/CC
Tie Rod Adjustment Sleeve SB
Center Link MP/CC
Idler Arm/Bracket CI/CC
Suspension Components(con’t) Strut Rods CI/CC
Torsion Bars GB/CI/CC
Shocks SB/CC
Rear End U-Bolts N/CC
Rear Leaf Springs N/SB/CC
Backing Plates GB
Spindles CI/CC
Anti-Sway Bars N/CC
Steering Components:
Pitman Arm CI/CC
Steering Box N/CC
Exhaust Systems:
Muffler Hangers and Clamps N
Exhaust System and Mufflers N
Gas Tank Components:
Gas Tank N
Gas Tank Straps N/GB
Gas and Brake Lines N
That's great help. Thanks again. Are the wheelhouses and underside body color or black?
Body color. But undercoating or sound deadener is often applied after that.
Also, I take exception to the above chart, as I have never seen a K-frame (subframe to which the front suspension, steering, and engine is attached) painted anything but semi-gloss black as-manufactured.
"Front unibody subframe assembly" refers to those short frame horns, shock tower/upper arm mounts, etc.., welded to and painted with this body. What they did there was spell out the difference between a full frame build and a unibody build. The K frame is the K frame, painted black and bolted to any color body after paint.
try and think "assembly line"
it would be very difficult for the line workers to assemble anything with painted threads or adjust and fit anything slopped with paint...those parts would be left uncoated.
all wheel wells were undercoated except some California cars which were blacked out just with paint
floors and frame sections were primer with some body color over spray
lower control arms were cosmoline (orange waxy oil coating)
there are guys on this site that know much more than me.
