1973 Duster Big Block 4 speed
Moose50
Moose
Menlo Park
I'm just about ready to begin my new project so I thought I would start a new thread. I'm waiting to get my new compressor wired into the garage and then I'll start the work. The Duster is a six cylinder and I will make it a 440 4 speed mini tubbed car. I will post some detailed pics of the car in the next few days.
I took some base photos of the car to show the starting point. I have a lot of work ahead of me and I know I will learn a lot ! I bought some quality equipment to help the process along and the shop will be wired for 220 on January 18th.
You have a lot of work ahead of you.
I did this to my duster. Be ready to install and remove the engine abou 5 times lol
Here was my build so you can see some issues I had.
http://www.forabodiesonly.com/mopar/showthread.php?t=33454
Have you done this befor? It's a fun build.
Brewers performance will be a friend when it comes to the 4 spd stuff. If you stay mechanical linkage that is.
Good luck!
The weather here in Cali has been a bit wet and work has had me a bit too busy to work on the Duster but I found time to try out my new Texas Blaster. it worked perfect right out of the box. I had one from Harbor Freight once and I thought I was smart trying to save a few bucks, but it was nothing but problems. I went to Home Depot on my way home from work and picked up 3 bags of play sand just to try it out and see if it would work. I haven't been feeling too lucky lately but I figured what the heck. I screened the sand through plain window screen. loaded it up, and fired up my new compressor. It was like magic and it only clogged up once and I think it was my fault because I opened up the feeder valve a bit too far.
Welcome from Pismo. Check out the Nor-Cal Mopar guys here. Damn cool to deal with.
Been busy with life and have been away from the project. Back at it on Tuesday. Updates to follow
Been busy with life but have found a little time fort the Duster. Its ready to be cut up for Tubs and a new trunk floor. Bolt in sub frame connectors after that.
